Ignition probs and XPI Xtra Power Ignition
I have a '64 F250 with a 70something FE 360, 4x4, np4350. I'm not getting spark in 2 plug wires at idle. Oddly, it sounds fine at idle. When I give it throttle I get spark in the 2 wires but it doesn't seem smooth and continuous, it seems erratic and weak which I suppose is why under load it's sputtering and popping. I have a new dist. Cap and new plugs and wires and new coil, truck ran great for a couple months now this. I had put a new coil in a few months prior to this one and it went bad. Both were napa coils. I'm planning on modifying the ignition system with MSD coil and distributer. Any input from you guys would be helpful; I don't want to replace all of this and have a reoccurring issue.
Also if any of you are familiar with ford's XPI "extra power ignition" box I'd love some input. If I use a blaster II coil do I still need the box? Could that be causing any of my issues?
Thanks for all your insight in advance!
Did you replace the rotor, points and condenser when you replaced the distributor cap, wires and coil? Can you tell which two plugs are not getting spark? Always the same two? You can check continuity with a meter from each outer post on the underneath side of the distributor cap to the center spark plug tip and see if it changes when you wiggle the wires.
Still have no idea what "XPI" refers to. It's not FoMoCo related, that's for dang sure.
DuraSpark electronic ignition intro'd in 1974. On 1974/79 F100/350's, the module was originally located on the left fender inner apron, just in front of the firewall.
DuraSpark dizzy has a stator aka magnetic pickup coil, takes the place of the points and condenser.
1974/79, there are five different modules and respective wiring harnesses, none of which interchange.
