Ignition probs and XPI Xtra Power Ignition
Old 01-22-2014, 08:57 AM
Cdouglas18's Avatar
Cdouglas18
Cdouglas18 is offline
I have a '64 F250 with a 70something FE 360, 4x4, np4350. I'm not getting spark in 2 plug wires at idle. Oddly, it sounds fine at idle. When I give it throttle I get spark in the 2 wires but it doesn't seem smooth and continuous, it seems erratic and weak which I suppose is why under load it's sputtering and popping. I have a new dist. Cap and new plugs and wires and new coil, truck ran great for a couple months now this. I had put a new coil in a few months prior to this one and it went bad. Both were napa coils. I'm planning on modifying the ignition system with MSD coil and distributer. Any input from you guys would be helpful; I don't want to replace all of this and have a reoccurring issue.
Also if any of you are familiar with ford's XPI "extra power ignition" box I'd love some input. If I use a blaster II coil do I still need the box? Could that be causing any of my issues?
Thanks for all your insight in advance!
Old 01-22-2014, 09:06 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
If you're idling on 6 cylinders, you should feel it. You probably really do have spark.
Load-dependent sputtering sounds like a carburetor, timing, or vacuum issue. I think you're wasting your time with the ignition system and the behavior you think you're seeing at idle is a red herring.
What does "went bad" mean? You're measuring winding resistance with a multimeter and comparing it to a spec? That's the only way you can say it's "bad."
You money is better spent elsewhere. Performance ignition carries quite a bit of marketing hype. A lot of people are going to tell you "it runs so much better" but they're not going to tell you in ways you can measure.
Never heard of it, and nothing came up in a Google search.
Old 01-23-2014, 08:40 PM
Cdouglas18's Avatar
Cdouglas18
Old 01-23-2014, 08:41 PM
Cdouglas18's Avatar
Cdouglas18
Old 01-23-2014, 08:43 PM
Cdouglas18's Avatar
Cdouglas18
My mistake it is aftermarket. It's from hunt manufacturing.
Cdouglas18
28
01-31-2014 03:19 PM
Cdouglas18
01-22-2014 10:31 AM
mchbts
01-22-2013 11:33 AM
BLaCkSiLo
Electrical Systems/Wiring
01-28-2004 03:04 AM
CACWBY
06-23-2003 07:27 PM
Quick Reply: Ignition probs and XPI Xtra Power Ignition
