2013 Ford Raptor - Sync is erratic - Ford Truck Enthusiasts Forums
Old 01-22-2014, 07:01 AM
RobNeville RobNeville is offline
RobNeville is starting off with a positive reputation.
Cool 2013 Ford Raptor - Sync is erratic
The Sync system in my Raptor has never consistently worked. I have taken it in to the dealership, done the Master Reset etc. It still totally turns off sometimes while I'm driving, doesn't connect to my Iphone 5 consistently. When it does connect and I make a call, I have to wait 2-3 minutes after the call before Sync "disconnects" from the call. It still shows it as connected and you can see the time of the call continuing to tick away as if I'm still on the call. I'm having to manually turn my bluetooth off sometimes to make it disconnect.
I don't know if the software is up to date. Don't know where I would look to find that out.
Anyone know what to do?
Old 01-22-2014, 06:28 PM
cparks cparks is offline
cparks is starting off with a positive reputation.
owner.ford.com is a site you can check if you have latest version.
Old 01-23-2014, 09:07 AM
FordIVTteam's Avatar
FordIVTteam FordIVTteam is offline
Official Ford Rep
FordIVTteam has a very good reputation on FTE.FordIVTteam has a very good reputation on FTE.FordIVTteam has a very good reputation on FTE.
Quote:
Originally Posted by RobNeville View Post
The Sync system in my Raptor has never consistently worked. I have taken it in to the dealership, done the Master Reset etc. It still totally turns off sometimes while I'm driving, doesn't connect to my Iphone 5 consistently. When it does connect and I make a call, I have to wait 2-3 minutes after the call before Sync "disconnects" from the call. It still shows it as connected and you can see the time of the call continuing to tick away as if I'm still on the call. I'm having to manually turn my bluetooth off sometimes to make it disconnect. ...
Hi RobNeville,
Please PM your VIN and I can check for any applicable software updates.
Antonio
Old 01-23-2014, 07:24 PM
powerstrokejunkie444 powerstrokejunkie444 is offline
powerstrokejunkie444 is starting off with a positive reputation.
I work for a ford dealership and know they came out with a addition reprogram that takes like 20 mins to do and I believe there is a tsb for the new iphone's not working with the sync system.
Old 05-14-2014, 07:20 AM
Komarh Komarh is offline
Komarh is starting off with a positive reputation.
inside ford man
__________________
ford
Old 05-14-2014, 12:34 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is online now
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
all sync's, imho, have issues - both my 2013's do - i won't buy another - and I've had fords for 30 years
Old 07-15-2014, 08:52 PM
PancakeF150 PancakeF150 is offline
PancakeF150 is starting off with a positive reputation.
I've had my Raptor/Sync for 3 years and I don't have that many problems but the only problems I've had had to do with the iPhone and no other phones I've owned. Steve Jobs and Bill Gates products don't work well together.
Old 07-22-2014, 08:53 PM
David1986's Avatar
David1986 David1986 is offline
David1986 is gaining momentum as a positive member of FTE.
My 13 Raptor Sync is terrible! Been to the dealer numerous times with no solution. Start the truck it will connect and play my iTunes for awhile, then the sound will go dead. Sync states it's connected and playing. It's even counting down the playing time, just no sound. Turn truck off, it will start playing again.
My C-Max works Great! Just not in my Raptorů...
Text message "send error" 2jhanna 2009 - 2014 F150 9 01-18-2017 06:53 PM
SYNC not responding to voice prompts LilredWagon 2009 - 2014 F150 8 10-16-2015 08:02 PM
2015 F-250 issues with Sync/phone nsrt 6.7L Power Stroke Diesel 6 11-24-2014 01:22 PM
SYNC problem -- can't disable privacy mode skizzo 2009 - 2014 F150 12 05-18-2014 10:20 AM
2012 Explorer's Sync montey2005 2011 & Newer Explorer 6 11-30-2012 11:18 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
