Door Interchangeability
I have an 89 F350 Lariat that has power windows and locks. I found a nice set of doors from a 95 F150 that also has power windows and locks. I know the 95 doors will bolt on to my 89 truck however I'm not sure about the wiring and I'm looking for a little info. Does anyone know if the wiring / plugs are the same??? I'd like to let the 95 door panels in place because I like the power window switch location much better than my 89.
Ok, if the bricknose connector half will mate with the OBS (92+) door connector, then just swap the pins around in the 95 door connector to mate with the appropriate wires on your truck's harness.
If the connector halves DON'T mate up, then you'll have to use your existing door side connector, and rewire it onto the 95's door harness.
Daniel5.0 is saying that since the OBS doors have a light in them, you'll have to run a wire up to your dome light circuit if you want it to work.
Coneynew
05-12-2003 08:06 PM
