Clutch pedal to the floor...
I am not the most amazing with diagnosing these clutch problems.
I have a 96 F250 with the 7.5L and the ZF5. I bought the truck and it had a pedal to the floor issue. I replaced the master and slave cylinders and it worked just above mediocre. Still has a shifting problem. I replaced the slave again cause the clip broke that holds it to the transmission. It engages before going to the floor but I still have to pull it back up by foot from the halfway mark. While its running and sitting still its very very hard to put it in gear. It also starts going if I am not holding the brake while pushing the clutch in. So...I have figured out that the clutch is still engaged with the clutch in. It also shifts absolutely fine when the truck is off if that makes a difference. Clutch does the same thing, but it goes into gears smoothly.
I am gonna go ahead and replace the clutch cause of this odd wear on it. Is it possible that the throwout bearing is the problem here? Also, when I had the slave cyl out I could wiggle the clutch fork quite a bit. Is this normal? Any help is great.
And yes I have bled it properly, several times. There is absolutely no air in the system.
This is why I hate hydraulic clutches. I've done a few rangers, and the only way to get all of the air out is to pull the whole system (master, line, slave) and bench bleed it. Those had a plastic line though. My old Probe GT had a steel line, and I had to use one of those vacuum pumps, and a lot of patience. Good luck.
You said the fork had a lot of play? Do you mean like up and down play? Depending on how many miles are on the clutch, and I really can't remember if the fork had a rod to pivot on or if it sits on a ball to pivot but if it's the ball then it's probably worn out and this can cause the slave not to be able to push the fork far enough to fully engage the truck. If it is just air in the system though,Try depressing the clutch pedal about half way down and leaving it sit over night like that. The pressure on the fluid should push the air back through the master cylinder vent. But IMO, if the clutch is wearing funny it's probably the pivot point on the fork is bad.
It is the plastic line. Which is like 90 new. So I ripped one off at the junkyard instead for $3. The guy I bought the truck from threw all the parts away. -_- So I had to start fresh. I am also gonna do a clutch replacement anyway. There is a full circle of play Mike1. Its the type that has a bar to press against like a pivot.
I will take it off and blench bleed it again. Then go to a clutch kit replacement.
get down under your dash and look up at the clutch/brake pedal bracket. check for play in the bushings and at the control arm where it connects to the master cylinder push rod. this is a common problem with these trucks as they get older and the symptoms you are describing point directly to it. when you depress the clutch pedal it should actuate the puch rod with virtually zero play.
there is likely nothing wrong with your pressure plate or friction disk. clutch wear usually shows up as slippage, not early grabbage and/or difficulty with dis-engaging.
I checked for flex in the firewall and there is none. There is a quite a bit of play at the bar from where the clutch pedal meets the Master rod. Maybe my issue is the pedal assembly itself too?
Originally Posted by Monteg0
Annnd only available at the dealership... I bought one for my old Ranger, should have gone that route!
I will try to get some pictures up tomorrow when I get a chance to mess around with it again.
get down under your dash and look up at the clutch/brake pedal bracket. check for play in the bushings and at the control arm where it connects to the master cylinder push rod. this is a common problem with these trucks as they get older and the symptoms you are describing point directly to it. when you depress the clutch pedal it should actuate the push rod with virtually zero play.
I got a replacement arm from LMC and issue solved. BTW, also got him to come down on the price because of the issue he couldn't fix...
that's what we're talking about.
when my clutch started getting difficult i went out and bought a master/slave . luckily, before i went to the trouble of installing it, i read about the worn bushing syndrome. sure enough, this was my problem.
take special note of the condition of the little pivot on the end of that control arm ... if it has been metal-to-metal with the clutch master push rod, it will be badly chewed, and replacing the little plastic bushing will end up being a VERY short-term fix.
