Counterclockwise 390 water pump - Ford Truck Enthusiasts Forums
Old 01-21-2014, 08:24 PM
arcticatdan arcticatdan is offline
arcticatdan is starting off with a positive reputation.
Looking for a counterclockwise water pump for a 390 for a marine application.
Old 01-25-2014, 08:15 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Interesting - take apart the one you have and look at the impeller, is it possible it has straight fins and can run both ways? If so, take a new one apart and if it has straight fins, it should be OK to use running reverse, yes?
I know 99% for a fact that no marine supply will still have a Ford FE pump in reverse rotation.
Old 01-25-2014, 01:19 PM
iggybob44's Avatar
iggybob44 iggybob44 is offline
iggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant future
Im afraid Art is probably at LEAST 99% correct.........a pair of FE Marine engines would likely have been in something like an old Chris Craft or Stephens, probably an old "Woodie" and likely 35 feet or larger......due to age, and fuel prices most would have been repowered by now, either with a newer generation of gas engine, or more likely with a pair of diesels...........You might search online for specialty marine sources for surplus engine parts, used parts for obsolete engines, etc.......possibly whatever vessel youve got has an enthusiasts website like this one.
Old 01-30-2014, 09:36 AM
RapidRuss's Avatar
RapidRuss RapidRuss is offline
FE "Freakin Expensive"
RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.
If the impeller is good in yours, and the casing..but the bearings and seal are just bad..have it rebuilt ? JMO..Good Luck...
Old 01-30-2014, 11:18 AM
The guy before me pulled it and got a rebuild at the local auto parts store. It is the wrong one. I do not think he even knew the difference. Might have to make a new impeller for it.
Old 01-31-2014, 06:51 AM
crazy96863's Avatar
crazy96863 crazy96863 is offline
crazy96863 is gaining momentum as a positive member of FTE.
Did a little poking around on the internet looking at pucs and such... I cant be 100% sure but I may have an idea for you...
The impeller appears to be pressed on. Since water flows from side to side rather than forward to back, it may be worth having the impeller flipped so the fins force the flow the other direction with the reverse spin. If this works, replacements should be easy to source in the future.
I would just keep an eye on the engine temp until its performance is deemed trust worthy...
Old 01-31-2014, 09:19 AM
Looks like I found one. FlowKooler.com. Theirs will flow both ways. I talked to them yesterday, their web site does not show that but they are going to change it.
Old 01-31-2014, 10:02 AM
crazy96863's Avatar
Cool. Better than improvising.
Old 01-31-2014, 10:04 AM
crazy96863's Avatar
That company has a lot of unique applications... Interesting.
urgent! ignition stuck ON/AUX psoition even with the key out irfreddy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 37 07-20-2016 12:53 PM
360-390 water pump swap?? Farmtruckn 1967 - 1972 F-100 & Larger F-Series Trucks 4 08-18-2015 01:31 PM
aluminum water pump??? greentruck72 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 03-12-2015 10:42 PM
Replacing the Water Pump Info fixxxer-upper 6.0L Power Stroke Diesel 23 10-10-2013 04:11 PM
C-6 behavior ? grinnergetter 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-24-2011 08:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
