6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Drain Water separator/wrench is on panel Help!
Old 01-20-2014, 10:23 AM
Hunt4jesus's Avatar
Hunt4jesus
Hunt4jesus is offline
I have read a lot on here about it, and before i drop some money at a mechanic i was gonna see what y'all think. I have a 2008 6.4 fx4 with 101,000 miles. I filled up and drove and drain light came on, shortly after the wrench appeared. I drained it underneath and a steady stream flowed out, and nothing changed. The truck is in limp mode and won't go higher than 65 ish. I ran code and it says p2269 which water in the fuel code. My question is can i delete code and see if it gets out of limp mode(will it?). I changed the filters yesterday and the lower filter had brownish gunk built up all over it. I cleaned out housing and lid. it has a steady flow of diesel but light remains on. Will it go off if fixed or do i need to clear code. Do i need to take in, i just don't wanna have to mess up that fuel pump. What y'all think.
Old 01-20-2014, 11:25 AM
senix's Avatar
senix
senix is offline
Received 1,406 Likes on 1,002 Posts
Pull the sensor and clean that off as well.
When you pull the engine mounted filter did you look in the fuel bowl for metal and gunk?
Also how often do you change the filters? Should be doing so around 10K miles using only oem filters.
Old 01-20-2014, 04:26 PM
RM2738's Avatar
RM2738
RM2738 is offline
Senix covered it well. You should also drain HFCM monthly depending on your fuel usage.
Old 01-20-2014, 05:12 PM
USArmyTaterness's Avatar
USArmyTaterness
USArmyTaterness is offline
Check the sensor well they use a conductivity type sensor that sets off when water connects the electrodes. could have gunk built up on em. so clean it up real nice and try again.
Old 01-20-2014, 08:48 PM
Hunt4jesus's Avatar
Hunt4jesus
sensor
can someone tell me how to change and clean the sensor. I do not want to mess anything up.
Old 01-20-2014, 09:33 PM
USArmyTaterness
Let me see if I can find my figures of the assembly it will give you the right idea don't hold your breath all my files seem to have walked off
Old 01-21-2014, 05:06 AM
senix's Avatar
senix
senix is offline
sensor is just to the right of the yellow handle.
Old 01-21-2014, 01:56 PM
RM2738's Avatar
RM2738
RM2738 is offline
The right side as in to the front of the vehicle.
Old 01-21-2014, 02:08 PM
senix's Avatar
senix
senix is offline
Right, should have explained that better.
bryanzzz
05-15-2015 02:54 PM
nmclella
01-31-2014 10:14 AM
mollikate
10-07-2013 07:20 AM
JR2980
01-06-2012 06:11 PM
Whitey Ford
02-27-2010 04:21 PM
Quick Reply: Drain Water separator/wrench is on panel Help!
