Front hitch options for a '90 E350? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 01-21-2014, 11:15 AM
danfinn danfinn is offline
danfinn is starting off with a positive reputation.
Anyone else run into this and figured out a solution? It doesn't seem like either Curt or Draw-Tite make something for this year van. I'm hoping to get a front mount so that I can carry my dirt bike on the front, the rear hitch is already spoken for by the bike rack.
I did order (by accident) a Draw Tite hitch which is meant for a '00 E350. It looks like it would probably fit but I don't think it would allow me to continue to run the front sway bar. Has anyone driven one of these with the sway bar disconnected? Sudden death or not that big of a deal?
Old 01-21-2014, 05:49 PM
Rick1025 Rick1025 is offline
Rick1025 is starting off with a positive reputation.
A universal receiver hitch is made by a few mfgs. I don't remember the mfg, but I think it was draw tite. I hve one on each of my 3 E-350's. I find them on Craigs list from time to time. I don't know part numbers.
Old 01-21-2014, 06:52 PM
Rick, I'm curious to know what years your 350s are and if you were able to retain the sway bar?
Old 01-22-2014, 08:10 AM
A 95 350 EB;a 2000 350;a 2002 350 Quigley w/high top. I used the front bolt on the sway bar mount for the rear mounting bolt on the front hitch.
Old 01-22-2014, 12:12 PM
Ah, OK. Those are all the newer frame. I compared mine to a buddies '00 van and his swaybar is further back then mine is. He was able to get his hitch in there w/o having to remove the sway bar. Gonna try and hack something together tonight.
Old 01-23-2014, 10:54 AM
I was able to install the hitch made for a '00 onto my '90 pretty easily. It was like it was made for that frame. I was able to re-use 2 holes and only had to drill 2. Left the sway bar unconnected, took it for a drive and didn't notice a difference. Sway bar permamently removed and new front hitch installed.
Old 01-24-2014, 12:27 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
your 90 is the same as my 87, and on my 87 i pulled a rear hitch off an econoline of the same vintage, and 2 holes per side lined up with existing holes in the front end of the frame, just had to drill a third hole in the frame on each side and bolted it right up. then had to trim the reciever a little to clear the pitman arm. with the bumper removed it was a very simple install. it happened to be a uhaul hitch that i got.
Old 01-24-2014, 01:51 AM
that's interesting. how about the sway bar, no issues there? there was no way my swaybar was going to bolt back up with the hitch in place. it would require fabbing up some really long brackets so that it would clear the side plates of the hitch.
Front Hitch impact on cooling? truckfella 1999 to 2016 Super Duty 11 10-16-2016 06:49 PM
Front Hitch impact on engine/tranny cooling? truckfella Modular V10 (6.8l) 3 07-26-2016 04:03 PM
2015 Expetidion Platinum 4WD 3.5 V6 Turbo boost v101998 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 6 06-02-2016 06:11 AM
Ye' Olde Wench & Trinkets for the F-250-SD Thomas White 1999 - 2003 7.3L Power Stroke Diesel 32 09-14-2015 10:17 PM
Front-mount hitch for 82 E350? packlet 1968-2013 Full Size Vans 8 09-25-2005 03:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
