To head gasket or not to headgasket
04 f250 6.0 . Slight coolant loss, moisture in egt but not sloppy wet. No smoke, but high pressure in degaus tank. Deltas are 8-11. Was told it was a head gasket leak allowing pressure to build fast and stay high. I have also been told it was an egr cooler leaking.
Thinking about doing studs, gaskets, oil cooler and egr delete all at once. Or just do egr delete and oil cooler replacement?
I have a new ficm with an atlas 40 tune. Blue spring mod, just changed oil and added hot shot secret. Open exhaust, and fresh fuel and air filters.
