GAS Tanks
#31
GAS Tanks
Tacson,
I visited your gallery and you've got a nice truck goin' there. I'm also going the 5.0L w/AOD in 54 Panel. I was wondering what you are using for a fuel pump for you EFI? Apparently, you didn't go with the in tank pump so I'm what you used for an inline pump. I got one from NAPA but I'm not ready to start it yet. Also where did you put the computer.
Thanks
Half Ton
Thanks
Half Ton
#32
GAS Tanks
1/2 Ton,
Thanks for the compliments and best wishes as you proceed on your 54'. Where are you getting your Motor and AOD from? The pump that I am using is off a 87 F-150. Mid 80's to Early 90's I believe, don't quote me, Ford trucks had a Frame mounted pump. Right now it is looking like the computer will end up in the right kick panel because I have OLD AIR Heating and Air unit that I bought used at Pigeon Forge Nationals in 2002 that is going underneath in stock heater location. Let me know if I can be of any further help. I am always glad to help out or at least tell you what I know. Thanks again.
#33
GAS Tanks
Tacson,
My donor car is an '89 Crown Vic with a 5.0L and AOD. I'm using the original Panel gas tank which was in good shape. I'm using a frame mounted inline pump and my fuel return line attaches to the filler pipe. I'm a little concerned about my fuel tank pickup which is somewhat smaller than the input to the high pressure fuel pump but I think that it will be ok. I'd have to do some serious work on the tank to change it.
Half Ton
Half Ton
#34
#35
#36
#37
GAS Tanks
4 Speed,
Thanks, no the columns a re the 67-69 models. They do not exactly bolt right up to a "Front" steer. Now had I used a 67- 79 Ford Clip like a 69-71 Tbird or 72-79 Mid size like Torino, Elite, or 77--79 Bird or Cougar it would have worked and been Sweet. I went to a 84 Ford Van Tilt. My friend Kenny Frye of Robbins, North Carolina cut off the factory ignition switch and took out all the column lock mechanisms and I am using it because it has the factory OD on the column. I normally trade with those Tilt Swingaways. There is a guy in East Tennessee who I trade other F100 parts for the columns. He also deals in 53-56's stock or modified. This is the same guy who I am going to be trading fenders with so I can get a regular fender in lieu of having that spare mount fender. I am off to the junkyard now to look for a spare tire out of a 84-86 Lincoln Continental. It is big enough not to look odd when in use yet small enough to sit behind the seat in the cab of my 55'. Thanks again
#39
GAS Tanks
The Chevy van and Maverick gas tanks, is there any problem with the filler neck being too low? For example, the previous owner of my truck installed the tank in the rear, however, when they installed it, the filler neck sits lower than the top of the tank so it only fills up about 3/4's and then drenches you shoes in that sweet smelling cologne. Anyway, would I be smarter to adjust mine or try to do a swap? Thanks.
Paul
Paul
#40
GAS Tanks
Originally posted by tacson
Slick Mo,
You are correct that is what made the Pinto so famous. I wonder why though everybody that sells Aftermarket tanks sells rear mount or under the bed mount tanks?
Talk to you all later.
Slick Mo,
Anyway it seems to me arguments can be made against where ever the tank is. Mine got move out of the cab for the sole purpose of space. And since I am beginning to think it will never leave the garage saftey isn't an issue.
hasta,
Rick
#42
#43
