1984 2wd f150..largest tires stock?
Old 01-22-2014, 10:34 AM
Rovernut's Avatar
Rovernut
Rovernut is offline
Originally Posted by Cole Neese
Whether it sags or not depends on which tire, load rating, and psi.
Suspension sag has nothing to do with tire selection. It's going to sag the same for a given load no matter what tire you use.
Where tire selection comes in to play is whether or not you get rubbing when it sags. Also whether or not a given tire can handle the load that's causing the sag.
If you meant tire sag, how far it crushes, yeah, that'd tire and load dependent.
Old 01-22-2014, 12:39 PM
Cole Neese's Avatar
Cole Neese
Cole Neese is offline
Yeah I know I misunderstood and thought he meant tire sag.
wikdwest
03-20-2016 01:42 PM
Northern Caveman
1978 - 1996 Big Bronco
04-21-2012 04:50 PM
SneakyF350
6.7L Power Stroke Diesel
05-21-2011 11:29 AM
wely
03-30-2009 07:52 PM
Mark Wenner
04-18-2005 04:53 PM
Quick Reply: 1984 2wd f150..largest tires stock?
