S-10 Frame Under A 40 Ford
Old 06-27-2003, 04:25 PM
MARTY SOUTH's Avatar
MARTY SOUTH
MARTY SOUTH is offline
I WAS WOUNDERING IF ANY ONE OUT THERE WOULD BE
ABLE TO LET ME KNOW IF IT IS POSSABLE TO PUT 88
S 10 FRAME UNDER 1940 FORD P/U .
MY CONCERNS ARE THE WIDTH OF THE THE RAILS ON
THE S-10 WHERE FIRE WALL MOUNTS
THANKS FOR THE HELP
Old 07-02-2003, 09:06 PM
TryMe's Avatar
TryMe
TryMe is offline
Marty ,I have found out almost anything is possible,if you work at it hard enough. I have never put a 40 on a s-10,but I have put a 40 ford p.u. on a Ford ranger. It was a light roll over ,that I bought it with less then 20 thousand on it. And I used everything.encluding the computer. But it was not just a drop on. lets see,all new body mounts ,new radiator ranger or s-10 wont work,I fibercated a new firewall that sat back 3 inches. Because I had to move the eng. and transmission back about 3 inches,so new motor mounts,shorten the drive shaft. moved the rear axle over the springs and install shorter coils in the front. Rewire the truck for the computer system. And a few other mods. if you thinking was it worth it,or would i do it again, YES I WOULD. But im in to building old trucks.
Good Luck !!
Old 07-03-2003, 09:04 AM
Carlene's Avatar
Carlene
Carlene is offline
Admom
Hey Marty - welcome to FTE.
You may want to check out the diagram and measurements of the original frame in my gallery. Should let you know if the frame you want to use will work or not without much altering.
Old 07-04-2003, 01:18 PM
41Clay's Avatar
41Clay
41Clay is offline
Hello Marty! Welcome to FTE!
More than likely you would have to change the wheel base by shortening or legthening the frame or bed. That would probribly be the hardest metal working project that you'll come across. If you went with the frame it would need to be exact and and if Chevy uses the same stregnth of steel on the frames as Ford does (on newer ones) you may need to have a shop to do all the welding to the frame. Shortening the bed isn't too bad of a job but if you legnthened it you would need to find a spare bed or something for the added legnth.
If the frame at the cowl isn't too wide it can be done pretty easily. It would take alot of time and patience but it can be done. If you have any questions just ask us and we'll see if we can help you out.
Clayotn
Old 09-19-2003, 04:08 PM
65van's Avatar
65van
65van is offline
Question S-10 Frame Under A 40 Ford
I'm just about ready to start mounting my 40 pickup cab on a 89 Ranger frame.
Should I Rubber mount the cab to the frame?
or bolt it up solid.
Thanks
Doug
Old 09-19-2003, 10:10 PM
shortyforty's Avatar
shortyforty
shortyforty is offline
It can be done.
In my case I lowered the cab down over the chassis. This required notching the doors and running boards, but my doors were already rotted in that area and I had to rebuild them anyway.
There is another 40 pickup in my area that is also on a S10 chassis, but he mounted his cab on top of the chassis so he didn't have to cut the doors.
The wheel base will either have to be lengthened or shortened depending on whether you use a long or short wheelbase S10.
I used a long wheelbase and moved the spring hangers forward then chopped off the excess frame rails to fit the bed on.
There are a few pictures in my gallery.
If I had the extra money I think I would have used a Ranger chassis and installed a mustang II front suspension. This may be in the future if I decide to go all Ford with it.
Old 11-19-2003, 10:52 PM
bluesman's Avatar
bluesman
bluesman is offline
Tracy,
Can you email info on your 40 ford p.u. on a Ford ranger frame swap. I want to do the same and am looking for direction.
Keeping the Blues Alive!
Dan
Bluesman
Blues-traveler @ earthlink . com
Old 12-01-2003, 10:37 AM
65van's Avatar
65van
65van is offline
Thumbs up 40 cab on 89 Ranger frame
I havn't started the mounting yet, still trying to get the body in shape. probably 80% done.
I plan on lowering the body onto the Ranger frame next month, then start building mounting tabs on frame ect.
I'll email you with progress, questions,
Doug
Old 10-16-2014, 08:02 PM
36couper's Avatar
36couper
36couper is offline
Sorry to drag up an old post. I just bought a 1940 pickup on an S10 chassis.
I don't see any evidence where the frame was shortened or lengthened
It is a pretty amateur build though. I guess the previous owner wanted the rat rod look but after I started disassembling it, it was clear most things need to be re-done.
I'm not a rat rod guy. I like things done properly and with nice paint. My vision is to paint it dove gray (1940 Ford colour) and some 17" or 18" wheels. It's a long term project. Luckily my next door neighbour restores muscle cars to concour condition for a living (mainly Mustangs, Shelbys etc) and he can help me get things straigtened out.
The wide whites, tires and rims will be for sale
Here is a pic
Old 10-16-2014, 08:09 PM
36couper's Avatar
36couper
36couper is offline
here is my other Ford. 1936 5 window coupe
Old 10-19-2014, 10:20 AM
Scndsin's Avatar
Scndsin
Scndsin is offline
That is a very nice truck. By most enthusiast's measure, it is a long, long way from "rat rod".
Since most S-10 searches will turn up this thread, could you detail your restoration in a new thread with link from here & possibly detail the mods done to use the frame.
Also, quick question. Prior to your deconstruction, did it steer, brake and generally operate in a safe manner or did you fear for your life when driving?
That 36' is gorgeous too.
Old 10-19-2014, 02:00 PM
36couper's Avatar
36couper
36couper is offline
Good suggestion. I will start a new thread when I began the disassembly and reconstruction. I have the box off now and will take some picture tonight.
Yes, it was ok to drive. It steered and stopped well although there seemed to be a little play in the wheel and the steering wheel was installed on center.
I plan on going over all of the suspension again to replace anything that looks even slightly worn. Plus, I am installing new front springs to get the front up a bit. The grille would drag going over a small curb.
Thanks
ac
Old 10-31-2014, 09:09 PM
fourspeedwagon's Avatar
fourspeedwagon
fourspeedwagon is offline
36couper- What part of the country are you in? I'd be interested in those wheels/tires
Old 11-02-2014, 04:45 PM
36couper's Avatar
36couper
36couper is offline
I'm one hour west of Toronto.
235/75 X 15 rear
205/75 X 14 front
Haven't set a price yet since I first need to find a set of wheels I'm going to replace them with. I have a couple of guys interested in them.
oldiron73
22
03-25-2020 10:15 PM
mmeserve83
1947 and Older Ford Trucks
17
01-10-2020 10:20 AM
StacksRacing
28
06-26-2017 09:42 PM
rnelson664
03-05-2017 06:26 PM
stevemaynard
08-15-2009 01:58 AM
Quick Reply: S-10 Frame Under A 40 Ford
