No Throttle Response DTC's P1235
Very common issue on late model Fords, Transit Connect included. If you have this code and nothing is obvious as far as a wiring fault the internal electrics in the electronic throttle body are to blame. Here I show how to change the throttle body out and reset the pcm to relearn the new one and get you back on the road.
