00 Expy Dreaded Misfire P303
I have a 2000 5.4 Expy and have been troubleshooting a P303 cylinder 3 misfire so far to no avail. I have swapped COPs with a couple of other cylinders to make sure that it was not a coil and found that the truck runs good until it gets up to normal temps and then it will hesitate when pressing the accelerator indicating a miss. I just pulled the plug to confirm it looks fine (3000 Miles on the plugs) and did find a small amount of what looked like coolant on the COP boot. To be sure, I stuffed a rag in the hole to make sure that there was no moisture before reinserting the plug and a differenct COP. There is no CEL, but I get a P303 on a code reader. I just pulled the fuel injectors and checked resistance before swapping the #3 out with the #1 just to confirm it was not an injector. At a glance, there is no broken wiring, however it looks like I will need to look at the COP connector and the injector connector wiring next. Any suggestions on what to do next would be appreciated.
I have a 2000 5.4 Expy and have been troubleshooting a P303 cylinder 3 misfire so far to no avail. To be sure, I stuffed a rag in the hole to make sure that there was no moisture before reinserting the plug and a differenct COP. There is no CEL, but I get a P303 on a code reader.
I have seen many boots crack, ground out the spark, and give you this code, even after flipping COPs.
Also, once you move them with removal, you really need to inspect closely. Also, plenty of dielectric grease.
Not uncommon to have a slight coolant leak and give you fits like what you describe.
Here's one of mine.
TexFinn
Modular V8 (4.6L, 5.4L)
05-10-2004 10:55 PM
