2013 Explorer transmission issue - Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer
Old 01-20-2014, 11:36 AM
55fordv8's Avatar
55fordv8 55fordv8 is offline
55fordv8 is starting off with a positive reputation.
Hi
has anyone had a problem with their transmission not shifting properly? It seems to mostly happen when trying to shift between 4th, 5th and & 6th and mostly when trying to upshift.
If you put the shift in manual and hit the + button it will upshift. I already had it at the dealer once for the same problem around 5k miles and they said there was a software download that needed to be done. Now it has 8k miles with the same symptoms.
Not thrilled with the funky little issues this car has.
Thanks,
Deb
Old 01-21-2014, 10:19 AM
FordService's Avatar
FordService FordService is offline
Official Ford Rep
FordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud of
Quote:
Originally Posted by 55fordv8 View Post
Hi
Thanks,
Deb
Hi Deb,
Shoot a PM my way so I can get your regional customer service manager involved. All I'll need to get things moving is your full name, best daytime phone number, VIN, mileage, and servicing dealer.
Crystal
78 C6 No Reverse, No 1-2 Upshift zdumpor Clutch, Transmission, Differential, Axle & Transfer Case 3 05-08-2016 06:32 PM
2011 Ranger Auto Trans Question Frdtrknut Ranger & B-Series 7 11-08-2015 09:31 AM
Strange noise/sensation on 1-2 upshift droldsmorland 1999 to 2016 Super Duty 23 10-30-2015 01:19 PM
2011 F-350 trans issue CDNMuddawg 6.7L Power Stroke Diesel 7 09-18-2015 06:26 PM
Does this match the symptoms of CAC condensation? QwkTrip 2009 - 2014 F150 30 04-13-2015 10:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
