Adding steel plate to strut and rear springs? - Ford Truck Enthusiasts Forums
Old 01-20-2014, 12:01 PM
cubangt cubangt is offline
cubangt is starting off with a positive reputation.
After installing the autospring 2" Leveling kit and the rear add a leaf 1.5" I was wondering if its at all possible to add a slight steel plate between the spacers and rear leaf to get just a little more lift.
I have access to our shop where I can get the steel and get it cut and drilled accurately, just wondering if this will cause any issues be adding additional plate?
Like for the front add it between the spacer and strut and in the back, when when I was adding the new leaf it had some shims I guess in between the leafs, so just curious if I could add the plate under the leafs?
I know it may be a stupid and dumb question and probably asking for trouble if I did it, but just want to know if anyone knows..
thanks.
Old 01-22-2014, 07:37 PM
awq134's Avatar
awq134 awq134 is offline
awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.
i'm assuming your truck is a 4x4. If so, there should already be a block between your leaf spring and axle housing. I would think it would be safer to replace the factory 1 1/2" block with a larger 3" block rather than stacking blocks together. I would think that the same would be true for the front. Perhaps you could remove the rear blocks and have your shop duplicate them, with a slightly taller dimension.
Old 01-23-2014, 10:41 AM
Not 4x4, wasn't looking to go extreme, just looking to get another 1/2" to 1" height without spending a lot of $$$$$
Trailer hitch 1oldtimer 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 12-16-2013 08:41 AM
[RESOLVED] New leaf springs bed still sags minnesotafisherman 1987 - 1996 F150 & Larger F-Series Trucks 47 10-04-2012 02:52 PM
adding coil spacers to existing 4" lift Bluebronco85 1978 - 1996 Big Bronco 3 09-16-2011 10:24 PM
rear add-a-leaf ride quality sandman3510 Brakes, Steering, Suspension, Tires, & Wheels 3 05-22-2003 11:55 PM
F350 rear spacer removal? TonyG Brakes, Steering, Suspension, Tires, & Wheels 3 06-13-2002 11:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
