Drain Water separator/wrench is on panel Help! - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-20-2014, 10:23 AM
Hunt4jesus Hunt4jesus is offline
Hunt4jesus is starting off with a positive reputation.
I have read a lot on here about it, and before i drop some money at a mechanic i was gonna see what y'all think. I have a 2008 6.4 fx4 with 101,000 miles. I filled up and drove and drain light came on, shortly after the wrench appeared. I drained it underneath and a steady stream flowed out, and nothing changed. The truck is in limp mode and won't go higher than 65 ish. I ran code and it says p2269 which water in the fuel code. My question is can i delete code and see if it gets out of limp mode(will it?). I changed the filters yesterday and the lower filter had brownish gunk built up all over it. I cleaned out housing and lid. it has a steady flow of diesel but light remains on. Will it go off if fixed or do i need to clear code. Do i need to take in, i just don't wanna have to mess up that fuel pump. What y'all think.
Old 01-20-2014, 11:25 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Pull the sensor and clean that off as well.
When you pull the engine mounted filter did you look in the fuel bowl for metal and gunk?
Also how often do you change the filters? Should be doing so around 10K miles using only oem filters.
Old 01-20-2014, 04:26 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Senix covered it well. You should also drain HFCM monthly depending on your fuel usage.
Old 01-20-2014, 05:12 PM
USArmyTaterness's Avatar
USArmyTaterness USArmyTaterness is offline
USArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant future
Check the sensor well they use a conductivity type sensor that sets off when water connects the electrodes. could have gunk built up on em. so clean it up real nice and try again.
Old 01-20-2014, 08:48 PM
sensor
can someone tell me how to change and clean the sensor. I do not want to mess anything up.
Old 01-20-2014, 09:33 PM
Let me see if I can find my figures of the assembly it will give you the right idea don't hold your breath all my files seem to have walked off
Old 01-21-2014, 05:06 AM
senix's Avatar
sensor is just to the right of the yellow handle.
Old 01-21-2014, 01:56 PM
RM2738's Avatar
Quote:
The right side as in to the front of the vehicle.
Old 01-21-2014, 02:08 PM
senix's Avatar
Quote:
Right, should have explained that better.
08 F350 6.4 Code P0088 Dano1017 1999 to 2016 Super Duty 3 04-18-2016 03:40 PM
Problems with repeated P0088 Code Dano1017 6.4L Power Stroke Diesel 5 02-26-2015 11:13 AM
Code P0088 Dano1017 General Diesel Discussion 0 02-24-2015 03:21 PM
MY FIRST AND PROBABLY LAST FORD! ryanbodden2014 6.4L Power Stroke Diesel 36 01-30-2015 06:24 PM
HELP ME SAVE SOME MONEY AT DEALER! HAVE WRENCH LIGHT AND SOME CODES ryanbodden2014 6.4L Power Stroke Diesel 1 12-26-2014 02:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
