alternator testing
Old 01-20-2014, 10:10 AM
RobertJohn's Avatar
RobertJohn
RobertJohn is offline
alternator testing
Can't the alternator be tested using a volt meter and putting the red lead to the big black/red wire and connector on the alt..
Then grounding the other end to the frame or something ?
I know my battery's are bad but I'm trying to check the alt..
Old 01-20-2014, 11:01 AM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
Yes if you want to check voltage out put of the alternator, you can either touch the red lead to the large lead on the alternator and the other to battery ground or just connect red to battery positive and black to battery negative. That will just give you a voltage out put but will tell you nothing on the amp output. If you can drive it, just about any auto parts store will check it for you free.
Old 01-20-2014, 06:05 PM
Tailgate77478's Avatar
Tailgate77478
Tailgate77478 is offline
DITTO. And if you can't drive it, our alternators are easy enough to pull out. A lot of auto parts stores have a machine they will put it on to test it.
86AC
12-05-2018 10:24 PM
Dan V
03-24-2015 10:25 PM
khakushia
12-06-2012 12:25 PM
gorzenl
1999 to 2016 Super Duty
09-07-2009 07:21 PM
dogg16
Bronco II
05-19-2007 10:20 AM
Quick Reply: alternator testing
