Urgent help needed!!!
Vehicle 2007 Ford Explorer Sport Trac with 4.6L
Ok, just did a head gasket replacement. Everything is now hooked back up. Now when we try to restart the car, we get lights, but nothing from the starter. Also the OBDII code puller can't communicate with the car. Also the security light flashes very fast when you try to start.
Does ANYONE have ANY ideas? PLEASE HELP!
The flashing Security light when trying to start it often indicates that the PATS/SecuriLock systems does not recognize the key. If you have another programmed key for the Explorer, try it, by itself, with no other transponder keys nearby.
If you did not change the PCM or the PATS modules out during this process, I would not expect the PCM to need to be reflashed.
-Rod.
-Rod.
Lucas Frink
1978 - 1996 Big Bronco
07-01-2019 09:04 PM
blue66tang95f150
01-11-2017 09:55 PM
jamesoncue
02-12-2012 01:09 PM
