2012 F250 6.7 MPG
2012 F250 6.7 MPG
First off new to the site, I've owned several fords and have always been a fan. Just purchased this 6.7 with 50k on it from a friend of mine and I choose it over a 6.4 I was looking at solely because of all the good mpg reviews. Truck is super clean and I bought it to work out of, I farm and most of my driving is similar to in town driving, truck will have about 1,500 ponds in the bed at all times " tool boxes, tools, air compressor". I drove it home 180 miles empty, about 14 mpg, I was expecting better, 16 or 17, I have a hard time believing the 20+mpg. Any way next two tanks yielded 11.6 and 11.7 mix of city and hwy. I bought a spartan tuner, egr, and dpf delete, also the truck had a air raid cold air intake when I bought it. That tank yielded 12mpg on 80hp tune all hand calculated at the pump although the lie o meter is pretty spot on. Anything else to ck the truck seems to run great. We have a 05 6.0 that gets 12.5 mpg with the same setup and driving, plus our old 7.3 we still have would get 15 to 16 when we used it, it's semi retired with 180k on it. Any input would be appreciated thanks in advance.
My 2012 F350 CC SRW 6.7L gets 17-18 hand calculated empty and easy driving mixed city/hwy. Lately I have been putting my foot into it and average about 16.5 hand calculated.
Some say you'll get less MPG running winter blend. we'll see what happens in the summer.
On average I'm getting similar results as my old 7.3L truck.
I drove 75 on the way home, and I was pretty excited my other two diesels if you keep them under 2000 rpms they get better mileage. This one ran about 1800.
Sometimes it may just help. Another thing that may help is to do a relearn of the tranny. Try to disconnect both batteries. Then turn on the headlights for a few and make sure all the electrical is discharged. That should reset the learning process all over to your driving habits.
Since you are farming you will want to service by hours vs miles. Also be careful of the fuel requirements for this motor. You need clean fuel. No water.
I don't know the gearing, I'm guessing 3.55 based on the rpms at 75 compared to other peoples trucks. I looked around the rear diff but didn't see any numbers. My truck is a '12 4x4 CC SB 20" wheels with stock tire size no lift all stock as far as suspension and tires.
As far as the trans it shifts nice and smooth I can do a relearn.
I have a 13 Platinum with 3.55 gears and 20s and I get 19 at 70mph. Got 23-24 at 55 flat land no wind. Average hovers around 15-16 when I'm not stepping on the throttle too hard.
Does anyone know how to tell what gear ratio my truck has? Is there a stamp on the rear diff, or some other way to tell?
With 20" wheels, your truck can only have 3.55 gears. My guess is the load you are carrying is a big factor. If a 6.0 got about the same mileage with the same load, I wouldn't suspect anything to be wrong with the truck. My experience has been that the 6.7 gets slightly worse mileage than my 6.0 did with light to moderate loads.
With a mix of highway and local driving I can easily average better than 17 mpg, but in purely local, around town driving my mileage is more like 14. Purely highway I can approach 20 mpg. I have seen as low as 12.5 mpg with city type driving and that was with nothing more than a small box of tools and my fifth wheel hitch in the bed.
