When to change batteries - Ford Truck Enthusiasts Forums
Old 01-19-2014, 10:31 AM
X-70STANG-F150's Avatar
X-70STANG-F150 X-70STANG-F150 is offline
X-70STANG-F150 has a good reputation on FTE.X-70STANG-F150 has a good reputation on FTE.X-70STANG-F150 has a good reputation on FTE.
I've been watching these batteries for a few months now. I'm not sure if they NEED to be changed now or if I can push them a little without damaging something.
After sitting all night (about 20dF here) both batteries are showing 12.5V
During a load test, both batteries quickly drop to about 10.5V, but hold that for 10-15 seconds.
Scangauge II
KOEO
FLP= 10.5V
FVP= 10.5V
FCM= 48.0V
These numbers do not drop during cranking and increase to 13.5V-14V directly after startup. I get a brief surging idle at startup for a few seconds and then all is good.
Old 01-19-2014, 10:46 AM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
With the extreme cold weather coming (-5) I wouldn't chance it as cranking amps go down the colder it gets and it will take more amps to crank over the thicker oil. I hate getting stranded and you could take out the starter. Best to load test them.
Old 01-19-2014, 10:55 AM
jswartz84's Avatar
jswartz84 jswartz84 is offline
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
Healthy batteries make a happy 6.0.
Old 01-19-2014, 11:33 AM
Quote:
That's my issue I guess. I got it through a week of below zero temps without issues. I don't even plug in unless its 10 or below. It started fine without plugging in after work also. If it were any other engine I wouldn't hesitate to get them through this winter and change them before next, but I don't want to stress the FICM or anything else.
Old 01-19-2014, 11:46 AM
clevelandtundra clevelandtundra is offline
clevelandtundra is gaining momentum as a positive member of FTE.
I pushed my luck and made it through that polar vortex nonsense a few weeks back, but one of the batteries was toast after that. Found out the hard way in my driveway but at least wasn't stranded someplace random. Sounds like you're about due.
Old 01-20-2014, 07:29 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
With those kinds of voltages, I'd replace the batteries as they look like they're getting weak.
I'll take a look at mine during lunch, but I don't think they drop that low cranking.
Old 01-20-2014, 08:56 AM
Quote:
I'd have to say I agree.
Thanks all that responded. I took the advice and went and picked up a couple of 875cca from NAPA. They have a $10 each rebate deal going, plus gave me a 10% AAA discount, and their base price was cheaper than the Diehards and Duralasts that I was considering.
I did not charge them so these numbers from this morning are after sitting on the store shelf, and running less than 5 minutes after install yesterday:
Scangauge II
KOEO
FLP= 12.5V
FVP= 12.0V
FCM= 48.0V
FLP and FVP did not jump right up to 13.5V like the old batteries did. When I started driving, they seemed to settle in about 12.5V-13V. Is that due to less demand on the ALT? The cranking effort was much better and ignition came about 50% quicker.
Old 01-20-2014, 09:40 AM
This link for FICMrepair.com answered a bunch of my questions. Like you guys recommended here, looks like I was riding the line. Looks like a good bunch of general 6.0 tips here.
Two problems - both ID'd - One fixed (battery)! (BOTH now fixed) F250_ 1999 - 2003 7.3L Power Stroke Diesel 18 01-12-2016 07:22 AM
FICM question Mark_in_co 6.0L Power Stroke Diesel 15 12-11-2015 06:01 PM
Batteries Rusty Axlerod 6.0L Power Stroke Diesel 16 03-07-2015 06:37 PM
Cold crank volts for 7.3 dyhrdford 1999 to 2016 Super Duty 13 12-04-2009 05:03 PM
No start "Sometimes" 01 Expedition Fordsfolly 1997-2006 Expedition & Navigator 3 05-05-2009 07:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
