Torque App on an OBS Powerstroke
#136
I recently bought a similar OBDII Bluetooth Scan tool, BAFX on Amazon for $23. Also works great with the Torque app for Android.
Question - bought it cause my engine light came on (Escape). Code is for the O2 sensor after the Cat. So, I set up the graphs in Torque for both bank 1 and 2 sensors after the Cats. After warm up, Bank 1 Sensor 2 (1x2) reads normal 0.18 V, however 2x2 reads constant 0.75 V (and this one jumped around alot at decel and accelerations.
Any clues? Possibly just the sensor, or, possibly the cat is already bad. 110,000 miles.
Thanks all.
Thanks all.
#137
You should start your own thread in the proper forum for your Escape. Nobody in this section has an O2 sensor in their truck and most don't have CATs.
That being said, bank 1 sensor 2 is the one that looks bad to me. The cats are suppose to remove all the oxygen from the exhaust and your O2 sensor should read ~.8-.9 volts in the absence of oxygen. If you have a multimeter and torch, you can test your O2 sensors (just check youtube for a video), or you can swap sensors from side to side and see if the voltage readings follow. Also, here's a thread I started when I had bad cats on bank 1 of my wife's Expedition. There's some good info in there... https://www.ford-trucks.com/forums/1...-misfires.html
#138
#139
#143
I have a BAFX dongle from amazon.
I remembered to take my tablet for the first time since I installed gauges and I noted that the Trans Temp was about 20-30 degrees higher with torque. The sending unit for the gauge is in the test port, where is the sending unit that torque gets its data from?
#146
#148
#150
Forums ? » Torque OBD ECU Scanner » Torque Discussion / Ideas » Trans temp, IAT, and MAPTorque
They have since added the "^" for powers so that makes it easier to input.
