Sync button not working
I can help you with that. Can you specify which SYNC prompt you're referring to? Are you referring to the voice command button or one of the other steering wheel controls?
Antonio
If the voice command button isn't responding, your system could be experiencing a software or hardware fault. PM your VIN and I'll see what other options there are to get the system restored, depending on your version of SYNC.
The voice command button may vary in exact location and appearance, but is signified by this symbol:
The button will respond to a single firm press, followed by an immediate release. Some SYNC newbies might make the mistake of holding down the voice command button for a couple seconds, which doesn't work. Just a single press should get SYNC to prompt you for a voice command.
Antonio
Antonio, I found it and mine works..Been using it for the phone and seems to work ok..gets confused from time to time on names but it prompts you to say what it needed to make call. I can tell you on my F150 it didn't work..I like so far,, keeps your eyes on the road and hands on the wheel..Thanks!
winginit,
Hi Go Big or Go Home!,
Antonio
Antonio
i am not overly impressed with the whole sync system thing. it does not hear me well and gets confused when i speak .
the turn by turn sux too, I see i will need a nav system
Just make sure you're waiting until after the tone and SYNC is finished speaking before giving your voice commands. This is a pretty common misstep. Other than that, I'm glad to hear you're enjoying the system so far! I'm happy to help.
yup that`s the symbol. The sync started working again maybe it needed a update.does it update from the net on its own?
SYNC is updated through the use of a USB thumb drive or by a dealership. If you're currently logged in, you can view any software available for download here: https://support.ford.com/tools/account/sync-software
You can view a nice walk-through of the download/install process here: Downloading an Update to Ford SYNC with a USB Drive | SYNC & SYNC with MyFord | Ford.com
To improve SYNC's voice reception and accuracy, make sure to follow the steps provided above. This will ensure the best possible experience when using the hands-free features.
Antonio
Go Big or Go Home!,
Hi winginit,
Antonio
Hi winginit,
Antonio
i could go to the dealer but i just want to do it myself! thanks!
