Like a new truck - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Like a new truck
Old 01-18-2014, 04:55 PM
Vinford's Avatar
Vinford Vinford is offline
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
Like a new truck
Ever since I bought my F-450 a few months ago it vibrated and made a noise.
I chalked it up to knobby winter tires and it being a 450.
I never drove it over 110 kms because it vibrated .
Yesterday I was going on a long trip and it seemed to get worse so I took out my hubs to see if that helped.
I leave them in usually all winter on the bush roads.
That didn't help and it got worse , very worse it started banging in the frontend , I pulled over but the highway was icey and busy so I kept going slowly looking for a place to pull off.
There was a load snap and a bang and the noise quit.
I made it to a driveway and pulled off and crawled underneath , the front ujoint/ball joint on the front driveshaft is floppy around barley hanging on.
So anyway I think that's been vibrating since day one and the loud cluck I heard was the hubs finally disengaging.
I think the hubs were stuck in and the driveshaft was still turning.
I made sure the driveshaft wasn't turning and carried on.
Went 700km and the truck drove like a new 1/2 ton.
I couldn't believe how nice it was to drive , it was smooth and seemed to even handle better.
So even though its going to cost $300 or so to fix its going to be well worth it.
Old 01-18-2014, 05:02 PM
golfmedik's Avatar
golfmedik golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
Glad you figured it out, but what a way to do it! By the way, I love the '08-'10 450s!!
Old 01-19-2014, 04:58 PM
cuda66 cuda66 is offline
cuda66 is starting off with a positive reputation.
Sweet! Glad you found it...not the best way I guess but never the less...I'll have to check mine as mine vibes bad from 85 to 100 km but at 85 it feels like a wheels going to fly off! I just assumed it was a bad wheel balance but it maybe this as well.
Old 01-20-2014, 12:23 AM
caddy's Avatar
caddy caddy is offline
caddy is starting off with a positive reputation.
Good find. Not ideal troubleshooting but sometimes the part has to fail before noise can be pinpointed.
Old 01-22-2014, 10:39 PM
Vinford's Avatar
This didn't turn out as good as I thought it was going to.
Its more than a ujoint , the whole end of the driveshaft is wrecked so need a new yoke and who knows what else.
Bought a driveshaft from autowrecker and it was almost as bad as mine.
Am getting a new yoke welded on another driveshaft now.
I can see its going to cost a bunch more than a ujoint..................
Old 01-22-2014, 11:10 PM
That really s*ucks.....would you just replace the unjoints then as a maintenance item now knowing what you do?
Old 01-24-2014, 11:14 PM
Vinford's Avatar
$850.00 and good to go again...............
Bad vibration in rear end, after doing a lot of work. RedDevil460 1999 to 2016 Super Duty 36 04-13-2016 04:56 PM
2003 Excursion - Vibration (lengthy) majestek12 Excursion - King of SUVs 27 09-16-2015 03:06 PM
drivetrain noise changed to vibration texkwik 1999 to 2016 Super Duty 4 04-11-2015 06:07 PM
2000 F350 grinding from front axle when in gear/under load CapeFerreloMetal 1999 to 2016 Super Duty 4 08-26-2013 04:50 PM
BW 1356 woes Robert Vandervennet 1987 - 1996 F150 & Larger F-Series Trucks 5 10-28-2012 04:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
