75K Maintenance - Did I miss anything? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-18-2014, 03:51 PM
Tawn's Avatar
Tawn Tawn is offline
Tawn is gaining momentum as a positive member of FTE.Tawn is gaining momentum as a positive member of FTE.
Just had my truck serviced at the 75,000 mile mark.
it's a 2008 F-250, SRW 4X4 Lariat.
Based on the owners manual and what I thought was a good idea, I had the following maintenance completed this week - did I miss anything?
1. Changed front & rear differential fluid
2. Changed transfer case fluid
3. Changed transmission fluid and filter
4. Flushed and changed the coolant
5. Fuel filters (every 10K)
6. Oil & filter (every 5K)
Old 01-18-2014, 04:12 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Looks good to me.... Did you miss an interval on the Fuel Filters? Every 10K would put it at 70 or 80K? Or did you do them early?
Old 01-18-2014, 04:16 PM
Tawn's Avatar
Quote:
Did them early. I just wanted to get it all knocked out the same day. Pain in the *** getting a ride to work, so I just had it all done in one shot.
Old 01-18-2014, 06:54 PM
mtmatzf150xlt's Avatar
mtmatzf150xlt mtmatzf150xlt is offline
mtmatzf150xlt is starting off with a positive reputation.
Im about at that interval also, I would recommend greasing the front u-joints also. Something that gets overlooked alot and could save you some hassle in the future if one decides to seize up.
Old 01-19-2014, 12:38 PM
Rudiak Rudiak is offline
Rudiak is starting off with a positive reputation.
Looks good. I am about to do the same except for the rear differential. The owners manual says it's lubed for life unless submerged.
No auto tranny fluid change for first 105K...concern? brychar 6.4L Power Stroke Diesel 56 07-16-2016 01:58 AM
When Maintenance Goes... UGA33 6.7L Power Stroke Diesel 8 03-24-2016 08:38 PM
can anyone send me links to walkthroughs/DIYs for maintenance? bigbuck75 1987 - 1996 F150 & Larger F-Series Trucks 1 08-30-2015 09:45 AM
140k E4OD Filter/Fluid Change fordvanguy88 Clutch, Transmission, Differential, Axle & Transfer Case 2 03-24-2013 11:48 PM
100K Miles = Time for some maintenance! kd0axs 1999 to 2016 Super Duty 17 11-09-2012 11:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
