55 carb linkage 351w - Ford Truck Enthusiasts Forums
Old 01-18-2014, 01:11 PM
wv1ton wv1ton is offline
wv1ton is starting off with a positive reputation.
351 w carb linkage using orignal peddle. has anyone done this, is there a kit.
Old 01-18-2014, 06:43 PM
71mach351's Avatar
71mach351 71mach351 is offline
71mach351 is starting off with a positive reputation.
I'll be trying this on my '53 and 351w combo. The original pedal is in. I have 2 female heim joints which will be connected by a 10-32 threaded rod. One end to the edelbrock carb the other will need to be connected to the original pedal rod. It looks like that end will need to be offset with a long bolt to make the link straight from the carb to pedal rod.
That's the plan anyway. The truck in in the deep freeze until work resumes in the spring.
Old 01-18-2014, 09:05 PM
DGMFORD's Avatar
DGMFORD DGMFORD is offline
DGMFORD is gaining momentum as a positive member of FTE.DGMFORD is gaining momentum as a positive member of FTE.
I could not make this work, 55 with a 351. I ended up with a lokar pedal and cable, works great. Mounted pedal to trans cover very comfortable
78 351m Edelbrock carb linkage herbiemin 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-16-2017 12:11 PM
Help! Need pic of throttle linkage on 87 351 Blue Rebel 1987 - 1996 F150 & Larger F-Series Trucks 0 08-15-2015 11:11 PM
Throttle linkage issue for 1955 F100 w/ 1963 292 jaggermk 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 06-01-2015 08:12 PM
kickdown rod/ linkage dmar68137 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-19-2014 06:33 AM
kickdown rod/ linkage dmar68137 1987 - 1996 F150 & Larger F-Series Trucks 2 07-19-2014 12:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
