Cummins swap/frame question
#421
#422
Oops, we are talking two different things. I think he's talking about the round piece you have to spread open to get around the column. The reason I think that is because that piece's length varies by whether it is a fixed or tilt column, and the piece you are talking about doesn't
Paul/RW - Please clarify.
#423
I dunno if it's length is dependant on tilt/non tilt, or manual/auto. I just discovered that the old one was too long.
Another clue is the fact that the TS switch wiring is visible in those last pics.....
Yeah, the firewall should be rock solid, seeing as the 3 layers add up to be about 1/4" thick, or more.
I could get the small plate into position rather easy. Holding it in place while trying to thread in the bolts was another story. The studs kept the holes aligned, and the weight of that input shaft kept it from lifting up as I tried to start the bolts. My next idea would have been gluing it in place, but that would have taken a bit longer to cure.......
I got it on there, and that's what matters.
#425
#426
#427
I considered it, but didn't think I could stick it down firmly enough, since I was using a long handled magnet to set it in place. That, and I didn't want to risk having it leak water into the floor, since the location is visible thru the cowl panel.......
Plus, I didn't have any with me.
#432
Amen! I suspect I'll get to see it when he comes up to get the stuff David left him as well as the shroud for the steering column. He probably won't need a radio antenna, center cap screws, or shroud before it is on the road.
#433
Gary is correct, I won't need those things till it's back on the road.
#434
Ran into a minor setback last weekend. Tried to turn the engine over by hand, and condensation had caused surface rust to form on the cyl walls. Soaked the cyls with penetrating oil and ATF. Spins over now.
Didn't want to force it past the rust ridges and risk damaging the rings, but after soaking with oil, it spun over pretty easy. Shot ATF several feet as each cyl came to TDC, and that was turning it over by hand. Would hate to see how far it would shoot out spinning it with the starter. That will have to be done though, before I can install the injectors......
That ATF in the cyls, should make the first start rather smokey....... At least the rings won't be dry.
Speaking of first start, planning to make it run before putting it in the truck. Maybe as soon as tomorrow.......
