6.4L Low Power- P0488 EGR Throttle Plate Codes - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-17-2014, 10:49 PM
makuloco2000 makuloco2000 is offline
makuloco2000 has a great reputation on FTE.makuloco2000 has a great reputation on FTE.makuloco2000 has a great reputation on FTE.makuloco2000 has a great reputation on FTE.makuloco2000 has a great reputation on FTE.makuloco2000 has a great reputation on FTE.
Ok so with age we are starting to see this code more and more and I figured it was common enough to do a video on just what it is all about. It has to do with the Egr throttle plate sticking in its bore and upon the sweep the pcm does it does no return to the full open position. In the video I show you exactly why it is flagging that dtc and how to replace the egr throttle plate with a few tips.
Old 01-18-2014, 08:17 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Great video! I am going to move this down to the 6.4 section.
Old 01-18-2014, 05:54 PM
Sounds good!
Old 01-18-2014, 06:36 PM
mtmatzf150xlt's Avatar
mtmatzf150xlt mtmatzf150xlt is offline
mtmatzf150xlt is starting off with a positive reputation.
Does this issue typically throw a check engine light or green wrench light or both?
Old 01-19-2014, 07:56 AM
senix's Avatar
It could do both since it is emissions and powertrain related.
Old 01-19-2014, 10:53 PM
Quote:
I have only seen the check engine light when they come in.
Old 01-21-2014, 10:27 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM BROWN DOG KTM is offline
BROWN DOG KTM is gaining momentum as a positive member of FTE.BROWN DOG KTM is gaining momentum as a positive member of FTE.
04 truck & PCM w/05 eng throw EGRTP code edwardbedrosian New Member Introductions 3 12-15-2014 03:38 PM
2004 PCM 2005 eng. and trans P0488 edwardbedrosian 6.0L Power Stroke Diesel 7 12-14-2014 10:27 PM
Error Codes P0407 P0488 nmclella 6.0L Power Stroke Diesel 39 01-18-2014 10:21 AM
stupid codes - please help me locate where to look for the problem. JaySVX 6.0L Power Stroke Diesel 11 01-28-2012 11:17 PM
p0488 KRDiesel 6.0L Power Stroke Diesel 3 04-07-2010 03:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
