truck wont start?!?!?!
ok guys im posting this for my friend she aint to truck smart yet.....she has a 1998 f150 4.6 liter 4x4 and she just bought the truck and its been having heating issues first it was the blender door was cracked so that was fixed then the temp gauge would sky rocket......so we changed the thermostat.......drove it around all day today and it barely warmed up and now it wont heat at all and it wont start now .....any help would be great guys thanks
Secondly....if there is higher mileage on this truck...the water pump maybe not up to the task?
As to why it wont start?...how may miles did you put on with the no heat condition? I'm sure that you changed the fuel filter
make sure the fuel pump primes...and there is good fuel pressure...and there is spark. And checked the relay & fuses for ignition and fuel?
under cold run...it may have shifted to fuel and air ratio tables to full fuel and essentially its flooded .... if you feel that spark is good & everything else is in line.
Take the battery cable off for 10-15 min....this should reset everything. then try holding the throttle to the floor while turning it over....so its turn it over and then floor it...continue to turn it over...this should shut off the injectors and it should start. if everything is working correct
bigmike1161
13
06-20-2017 11:05 AM
OldSchoolGrunt
11-09-2010 11:52 AM
Orpackrat
1983 - 2012 Ranger & B-Series
12-27-2009 08:23 PM
Komputersman
11-30-2005 08:15 AM
