Positive traction 1966 F250 4x4 - Ford Truck Enthusiasts Forums
Old 01-17-2014, 09:46 PM
pm042070 pm042070 is offline
pm042070 is starting off with a positive reputation.
I'm working on my 1966 F250 4x4 and looking to put positive traction in front and rear axles but unsure how to proceed. I'm going to swap out the 4.56 gears for 3.54's and would like to add positive traction in the process. I know carriers will have to be swapped to allow the higher gears but what else needs to be purchased to add positive traction front and rear? Any help / advice would be appreciated. Thanks!
Old 01-17-2014, 09:58 PM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is online now
crazed87bronco is gaining momentum as a positive member of FTE.
Probably best to get some axle rebuild kits while you have them torn apart. Bearings/seals you will need a 3:55 ring pinion gear setup and install kit along with the lockers of your choice.
Limited Slip Recommendations cwtaylor737 1999 to 2016 Super Duty 18 11-13-2014 02:11 PM
Dana 61 or Dana 70 3.07 axle pm042070 1961 - 1966 F-100 & Larger F-Series Trucks 2 11-06-2014 10:44 PM
Definitive Answers on Traction Control System (2011+ models) troverman 1999 to 2016 Super Duty 8 06-25-2014 07:24 AM
SAS questions (beating a dead horse) Brysonw 1987 - 1996 F150 & Larger F-Series Trucks 12 05-30-2014 01:17 PM
1977 4/4 w/ 9" read end rjbuningsr 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-07-2014 09:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
