Old Tools - Page 2 - Ford Truck Enthusiasts Forums
Old Tools
Old 01-18-2014, 04:59 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
second from the left is a hand vise, often used to hold small items while cutting, filing etc that were too small or difficult to hold in your hand. The open end wrench (far left) may have fit a specific fitting or nut etc or may have been a general purpose wrench.
Old 01-18-2014, 05:54 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Quote:
My uncle had one of these that he called a Third Hand.
Old 01-18-2014, 09:52 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Dawg, please pardon the hijack.
Here's an old tool that I've had laying around for quite awhile. Has anyone seen one of these? What is it? whats it used for? I have it sitting next to a pocket screwdriver for reference.
Thanks
Old 01-19-2014, 09:04 PM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
Sadly I have an old tool problem. I buy them at swapmeets, online and even antique malls. I use them everyday at work, then use the rest at home, even have old equipment. All my tools will out last me and go to someone else.
http://www.garagejournal.com/
Old 01-19-2014, 11:18 PM
fabieber fabieber is offline
fabieber is gaining momentum as a positive member of FTE.fabieber is gaining momentum as a positive member of FTE.
The tool on the bottom is an adjustable wrench. You simply open the jaws, put it over any size nut (within its opening range) and whether tightening or loosening, when you push down on the handle the top teeth grab and lock the nut between the top and bottom teeth. It is quick in that it automatically adjusts and grabs much better than a crescent wrench. I actually use the one I have quite often particularly in tight spots where the crescent wrench can't grab as well.
When my dad died in 1990 my brother and I were tasked by our mother to empty his little woodworking shop. There was an unfinished table leg in his wood lathe. I still have it...will always keep it and it seems like yesterday when I found it. Great memories come from things that are practically worthless to others.
Old 01-20-2014, 08:33 AM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Quote:
Yup, the objects probably have little value, but bring back strong memories, and that makes them priceless. Which is why I still have all of my dad's tools, old trucks, and even the hat he wore.....
Call me sentimental I guess.
Old 02-16-2014, 05:07 PM
1oldtimer's Avatar
I just got another one, a 1928 south bend 9" junior. I still have to put the drive belt on.
Axle Seal Replacement inspector747 1999 to 2016 Super Duty 0 02-13-2015 08:02 AM
seal at tranny schoo 1961 - 1966 F-100 & Larger F-Series Trucks 18 09-19-2014 12:10 PM
HAs anyone done the rear main seal replacement: green 69 1999 - 2003 7.3L Power Stroke Diesel 16 05-26-2012 09:41 AM
Front diff seal??? GreatWhite99 1999 - 2003 7.3L Power Stroke Diesel 3 02-11-2011 03:52 PM
Stubborn Rear Main Seal JimyTug Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 02-23-2006 07:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
