Need Brake Help - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Need Brake Help
Old 01-17-2014, 06:01 PM
Tri865 Tri865 is offline
Tri865 is starting off with a positive reputation.
Need Brake Help
Hello new to site. I need some help. I own a 2010 Expedition 4WD with 29,000 miles on it. My right front brake is hanging up. I have completed the following repairs, both rotors turned(less than 29,000 miles on vehicle), caliper (replaced twice on right side), new caliper mount, 2 new brake hoses on front, new brake shoes each time, brake fluid completely flushed, power bleed brake system. The right front brake pads are only making contact on the upper inch portion of the rotor and are dragging. The rest of the brakes are fine and the brake pad contacts the full width of each rotor. I can turn the wheel its not locked up. The rim get hot to the touch the rotor is really hot with brake smell. I dont know what else to do next.
Old 01-20-2014, 05:47 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Sounds like something is bent. I would take it to a shop you trust.
Old 01-20-2014, 10:58 PM
bunky383 bunky383 is offline
bunky383 is starting off with a positive reputation.
did you check your wheel bearings?
Old 01-22-2014, 04:08 PM
Yep, bearings seem fine, the hub is cooler to the touch then the rotor, no grinding or whining from the hub.. The caliper and the rotor are getting hot. Hard to tell how much because its 10 degrees here. Someone told me the brake pads might have a high spot on them. I'm going to take them off this weekend and see how level they are, maybe put the old worn ones back in and see.
Help with bad brakes (long post) Steven Day 1997 - 2003 F150 4 08-18-2015 07:58 PM
Lost My Brakes whale15 Ranger & B-Series 5 08-06-2015 11:16 AM
Need Brake Hlelp/Advice RobRoss Excursion - King of SUVs 13 05-29-2015 08:13 AM
2001 Expedition passenger side brake pad wear indicator position? BaitGuru 1997-2006 Expedition & Navigator 4 01-20-2015 06:53 PM
replaced rotors / pads still shaking jbh114 2009 - 2014 F150 25 04-27-2014 07:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
