Non turbo 7.3 hard/no start
A buddy of mine has a 90ish f250 with the non turbo 7.3 in it. It is extremely difficult to get it fired up. Once started it runs great and doesn't smoke a bit. We changed the plugs and checked voltage to them, they all have 12 volts to them. He replaced the lift pump also. It still won't start. He's not very mechanical and I've never been around these engines so I don't know any of the common problems with them. I think it has around 175k miles, and I assume original pump and injectors. I need some ideas. Thanks.
First things first... easy to hard:
1. Injector return line kit. Get a good one with viton o-rings, and the little black "olive" o-rings for the fuel filter head and rear of the injection pump
2. Check fuel tank switching valve for movement and in proper working order
3. New injectors and injection pump SHOULD be changed out. Not HAVE to, but should. Their general life expectancy is somewhere in the range of 100k-120k miles.
There may be other fixes, but the return line is definitely where I would start first.
On a side note, what glow plugs are in it? Should only be using Motorcraft/Beru ZD-9 plugs. Any others are not trusted by the IDI community.
And don't get an eBay return line kit and expect it to work right. If you can get a hold of user TypeFour, he can hook you up with the right stuff.
You mean the hard line? Or a soft line? If it's a soft line, it goes back into the return system. If it's the hard line, that's the actual return line back to the tank.
idi1993f350
09-15-2016 06:53 AM
big ole ford
02-27-2014 09:46 PM
Freedom 101
06-27-2012 11:26 PM
jdr0273
35
11-27-2006 01:47 PM
