Newbie Tuner ? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Newbie Tuner ?
Old 01-17-2014, 10:40 AM
diamondrcattle diamondrcattle is offline
diamondrcattle is starting off with a positive reputation.
Newbie Tuner ?
I am running the 250 tune with egr and dpf delete on a Sparten Tuner. I use this truck for feeding cattle and occasionally pulling a trailer. I am not after really hot rod stuff, but I want the best fuel economy I can get. I have seen you guys post that the hotter the tune the better the fuel econ. Now my question, if I am pulling something or go to pass someone on the road, it has so much power the turbo is hitting 40 psi according to stock dash gauge. Should I worry about that? I am not driving heavy footed, I drive it like I want it to last. Just concerned about blowing the turbo. Thanks for your comments
Old 01-17-2014, 09:55 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Many people will say that these trucks will handle 40-42 lbs of boost all day. I'm not convinced yet... I've been conservative and run my Defuel at 32 lbs boost. Also, you're more likely to stretch the head bolts before blowing a turbo due to boost.
Old 01-18-2014, 02:44 PM
STROKINMY'08's Avatar
STROKINMY'08 STROKINMY'08 is offline
STROKINMY'08 is gaining momentum as a positive member of FTE.
he's right the head bolts would come wayyyyyy before you would hurt the turbo.. the whole idea is the power/boost is there "if" and "when" you need it... passing someone you shouldn't be at 40lbs longer then what 4-6 seconds.. it's not going to hurt you.. it's the guys that go from light to light smoking people out.. who are at max boost all the time.. my thing is too much of a good thing....always becomes bad... maintenance your truck...drive with some sense and you'll be fine
Old 01-18-2014, 10:25 PM
GHeTTo JOe's Avatar
GHeTTo JOe GHeTTo JOe is offline
GHeTTo JOe is starting off with a positive reputation.
just curious if anyone that pushes 40+ psi boost if the stock gauge pegs at 40 or if it will go past evenly like it would if there was more numbers like 50 or 60 psi marking.
Old 01-19-2014, 09:13 AM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
I blew a HG towing my trailer over Mount Eagle TN. Looking back I "think" I may have been on a tuner level other than" stock". My advice would be to tow only on stock tune. Or you might learn a $5700 lesson.
2002 7.3l powerstroke tuners Jake_f16 1999 - 2003 7.3L Power Stroke Diesel 13 09-09-2016 03:40 PM
My Impressions Driving a Tuned vs Un-tuned 7.3 ARW 1999 - 2003 7.3L Power Stroke Diesel 36 10-04-2015 12:44 PM
SCT tuner issues on 2008 F350. 6.4L j5cents 6.4L Power Stroke Diesel 1 04-09-2015 10:19 AM
SCT tuner question ultrasks700 6.0L Power Stroke Diesel 15 01-10-2015 10:39 AM
Custom tunes jlmotox 6.0L Power Stroke Diesel 19 08-15-2014 10:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
