F150 AOD - Ford Truck Enthusiasts Forums
F150 AOD
Old 01-17-2014, 07:59 AM
boss429's Avatar
boss429 boss429 is offline
boss429 is starting off with a positive reputation.
F150 AOD
Hi, I have a 1993 F150 5.0 4X4 flair side with an AOD auto trans. It's in need of rebuilding. I was wondering if an AOD trans out of an '89 5.0 Crown Vic will fit if I swap out the tail shaft and housing for the transfer case?
Thanks for any help fellas.
Old 01-17-2014, 10:26 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Fit yes.. last no. Early AOD's were weak and car versions among the most poorly equipped, and you would have to completely dismantle it to change the output shaft. Your best bet is to find one from a 4x4 truck or just rebuild the one you have and install a street shift kit for long life.
Wiring harness interchange Osiyo59 1987 - 1996 F150 & Larger F-Series Trucks 4 01-30-2015 02:23 PM
1991 F 150 5.0 Codes AOD trans manutd1910 1987 - 1996 F150 & Larger F-Series Trucks 18 01-15-2015 03:09 PM
AOD VS AODE BIGWOOD 1987 - 1996 F150 & Larger F-Series Trucks 7 05-02-2014 05:31 PM
aod to manual trans hambone3531 1987 - 1996 F150 & Larger F-Series Trucks 2 02-22-2014 11:47 PM
aod with no od. Greasemonkey93 1987 - 1996 F150 & Larger F-Series Trucks 13 01-15-2014 09:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
