Fuel Sender for Stewart Warner Gauge - Ford Truck Enthusiasts Forums
Old 01-17-2014, 12:46 AM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
Anyone using a Stewart Warner gauge in their truck with a stock tank? I know I need the SW range sending unit, but don't know which direction swing or depth?
Long shot but thought I would try.
Thanks,
Dave
Old 01-17-2014, 10:22 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Thanks,
Dave
I can't say for sure but the SW gauge is probably looking for a resistance reading of 240-33 ohms. This is common for some aftermarket, marine, and even some OEM sending units. You can get an adapter from Sacramento Ford Parts that will allow a matching 12V aftermarket fuel sender to fit your stock tank but it is not likely you can make the gauge work with the stock sender.
Old 01-17-2014, 12:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I also have a S-W fuel gauge I got at a swap meet (for $1!), this is what I found for senders from their catalog. Note it is for 5-hole mounting, I'd swear the stock sender has 6 holes.
Old 01-17-2014, 01:29 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
Yea Ross the stock is a 6 hole and you need an adapter, I made mine on my lathe. They can be found for 20-30 dollars. The ohm range needed will depend on the gauge, SW along with the others make several ranges for use with stock senders so you will need to know the range for your gauge.
Old 01-17-2014, 10:46 PM
dmack91's Avatar
Thanks all. I knew about the ohm range, but was wondering if anyone knew for sure which one would fit our stock tank. Looks like I will go with the top one on the list.
Wiring Aftermarket Fuel Gauge...??? deyomatic 1957 - 1960 F100 & Larger F-Series Trucks 2 04-25-2015 08:09 PM
Which Stewart Warner Fuel Sender '60 F100 deyomatic 1957 - 1960 F100 & Larger F-Series Trucks 0 03-13-2015 09:23 PM
wiring mustangpt 1961 - 1966 F-100 & Larger F-Series Trucks 2 01-21-2015 10:44 PM
thought somebody may want/need... Maltman 1957 - 1960 F100 & Larger F-Series Trucks 0 09-12-2014 07:45 PM
eBay Oil Pressure Gauge Chevy_Eater Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 02-02-2014 11:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
