Hood Latch Rivets
Old 01-15-2014, 05:15 PM
cts1954's Avatar
cts1954
cts1954 is offline
Hood Latch Rivets
Does anyone know where I can get a couple of shoulder rivets for the hood latch on my 52 F1. They are a 5/16 shoulder rivet that are used on the pivot of the latch and the lever.
Thanks
Old 01-16-2014, 12:17 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
I don't recall anyone ever asking that here before. Maybe ND Bill
would know if there are any. I am thinking ya may have to have
them made for you. I think Ross or others will chime in.
Old 01-16-2014, 08:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Hmmmm.... You could probably make one from a bolt, this is all I could find. A bag of 50 may not cost a bunch, or you may be able to get a "sample"....
http://www.spaenaur.com/pdf/sectionE/E7.pdf
Old 01-16-2014, 10:06 PM
arctic y block
Yes Ross I would prolly try modifying a soft bolt with a bench grinder or if lucky a lathe. Than heat it red hot and rivet it down. I bet it would take me a few tries to get
it tight but not to tight. Sounds like a fun project to do. Several ways to do it.
Old 01-17-2014, 09:45 AM
cts1954's Avatar
cts1954
cts1954 is offline
Thanks, they are available but getting the small amount required is hard. Normally McMaster Carr has everything but I don't see these. I will make something out of a 5/16 shoulder bolt. The only reason I am replacing them is at one time my latch was chromed and I need to drill out the old rivets so I could strip the old chrome off.
tip49
09-18-2021 06:46 PM
r_reed
WTB - Parts & other
07-29-2015 08:17 PM
hillbilly1951
10-04-2012 09:30 PM
richardvestal
08-10-2005 01:42 PM
MO51
12-10-2001 05:43 PM
Quick Reply: Hood Latch Rivets
