EGR delete - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
EGR delete
Old 01-16-2014, 07:38 AM
diamondrcattle diamondrcattle is offline
diamondrcattle is starting off with a positive reputation.
EGR delete
First post here, thanks for the tons of info. My feed truck is an F-350 with the 6.4L 2010. I hated the regen and just put a Sparten tuner and dpf delete pipe in it. Totally different truck. It will keep up with my 6.7L now.
They offer an egr delete. I loaded that tune with the 250hp. What are the PROS and CONS of NOT doing a complete delete and just controlling electronically? According to sparten the egr valve will not opened when deleted unless pressures get high. So why pull it out if I wasn't having any previous issues???
Thanks for your thoughts.
Old 01-16-2014, 08:16 AM
bubbasz1's Avatar
bubbasz1 bubbasz1 is online now
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
My personal thought are if you do an EGR delete electronically you might as well take the coolers off so you don't ever have a coolant issue with the egr coolers leaking. It doesn't happen very often in the 6.4's but it has happened. You also don't have all those exhaust gases going through your intake, mucking things up.
Old 01-16-2014, 10:37 AM
Quote:
Not completely familiar with how egr works on a diesel, but if its deleted electronically wint exhaust gasses be very limited running thru intake if it remains closed except under high pressure? Educate me! Thanks
Old 01-16-2014, 03:02 PM
bubbasz1's Avatar
If you delete it electronically the egr gasses are gone, you only have to worry about an egr cooler leak, although the 6.4 isn't really known for that it does happen.
Old 01-16-2014, 07:54 PM
GSchretter's Avatar
GSchretter GSchretter is offline
GSchretter is gaining momentum as a positive member of FTE.
I've ran the CMD EGR = 0 for two years (Custom tune to set all EGR % to 0) along with block plates and the intake was as clean as I bought it new.
So it works fine but my concern was is if they leak and I wanted to put on RCD SS headers so off it goes.
Old 01-22-2014, 02:32 PM
winklershop winklershop is offline
winklershop is starting off with a positive reputation.
has anyone figured out how to do a EGR STEALTH DELETE on these 6.4's? same idea as the 6.0 L but there is more to these. weld the ends of the egr coolers shut, and leave everything inplace so it looks stocks, passes visual emission inspection.
Old 01-22-2014, 02:35 PM
also....has anyone figured out the DPF STEALTH DELETE. drill out the honey comb in DPF and tune it, this way it passes visual inspection, and then you only have to buy a tuner to reprogram the computer, and you dont have to buy the exhaust pipe replacement. those DPF kits are spendy
stealth egr delete troy676 6.0L Power Stroke Diesel 14 08-26-2015 11:36 PM
HELLO! new guy with an easy one asking about Freedom Diesel performance MR Smitty 1999 to 2016 Super Duty 3 08-22-2015 11:43 AM
DPF Delete???? diamondrcattle 6.7L Power Stroke Diesel 18 03-22-2015 06:19 PM
08 6.4l egr delete tuner 08F250SD_Laredo 6.4L Power Stroke Diesel 1 05-04-2014 03:52 PM
Scanner/Codes needed for EGR delete? Jowen1017 1999 to 2016 Super Duty 7 03-22-2013 03:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
