weldporn: the beautiful and the ugly - Ford Truck Enthusiasts Forums
Old 01-16-2014, 12:07 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Instagram
compare a proper weld with penetration and one of gobbed on filler rod with no penetration.
Old 01-16-2014, 12:30 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Battery and a coathanger?! To be fair, the "good" welds appear to be TIG. But no contest!
Check out the "Incredible Welds" thread on the HAMB sometime. Incredible welds - THE H.A.M.B.
Old 01-16-2014, 01:39 AM
smallello's Avatar
smallello smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
If the welds look that bad why keep making more bad welds? Wouldn't it be obvious that something is just not right?
Old 01-16-2014, 01:42 AM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Exclamation
I guess that maybe one can tell unwholesome and unsafe welds from an Internet photo. .
Old 01-16-2014, 02:00 AM
75Three90's Avatar
75Three90 75Three90 is offline
75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.
There are welders then there are grinders. I am a grinder my welds may be ugly but I have never had one break
Old 01-16-2014, 03:38 AM
Normalbloke Normalbloke is offline
Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.
I find men and welding are like criticising men's driving,oil selection and navigation skills. Nobody does it better, everybody is THE expert, and they won't have a bad word said about it, let alone accept criticism, positive or not! Generally, like!
Old 01-16-2014, 08:57 AM
toby tough's Avatar
toby tough toby tough is offline
toby tough has a good reputation on FTE.toby tough has a good reputation on FTE.
EEEEWW.I welded like that when I was first learning.I'm not as good as the good as the good welds yet. Someday.
Old 01-16-2014, 09:08 AM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Nobody seems to display their bad TIG welds , but then who wants to show off a hole in a peice of steel !
Old 01-16-2014, 11:14 AM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
All I see is an ad for Instagram...whatever that is.
Old 01-16-2014, 11:22 AM
ryans88gt's Avatar
ryans88gt ryans88gt is offline
ryans88gt is gaining momentum as a positive member of FTE.ryans88gt is gaining momentum as a positive member of FTE.
the number of internet experts on welding is amazing. Ask any of them to see their cetification and listen to the crickets.
in the case of welding, a picture is basically meaningless.
sonic testing, pressure testing, etc...
Cut the weld in half and inspect it.
strength test it.
Show the data.
But a picture... worthless.
my experience with a pipeline welding crew was that some of the ugliest welds were the strongest.
Old 01-16-2014, 11:31 AM
Chris 56 f6's Avatar
Chris 56 f6 Chris 56 f6 is offline
Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.
Baptism by drowning
I had a client that wanted some Arbors so I came up with this and she said " I ll take three. Plus I would like some gates made too"
I used this hot pierced bars . If you look real close you can see that the bars in the add are only welded on the sides. Not at where they pierce each other.?
I make up a sample and show the owners . The husband was partners/owners for a big tool box / truck box / job box compony( knaack / weather guard) he said that was great but that he would like all the holes filled with weld!
So I welded and welded and .....by the time I was done . I could weld OK.
Three years later he asked me to do his deck rails the same way. All 37 sections.
O yea this was my first welding job ever.
Old 01-16-2014, 12:25 PM
ALBUQ F-1's Avatar
postin' fool
Visual inspection of welds is THE primary weld quality control method, take a look at AWS literature, ASME Sections, etc. Not every "ugly" weld is bad, not every pretty weld is good, but some welds can easily be rejected or flagged for NDT based on a visual inspection - or a picture on the internet - if you know what to look for.
Old 01-16-2014, 02:26 PM
AXracer's Avatar
Quote:
The picture caption indicates these were two pipes made for the same customer. The ugly one was done first by someone who's price was 1/2 the quote of the second fabricator. He got what he paid for. I think even Stevie wonder could pick out the good weld. I suppose an ugly weld may be a (structurally) satisfactory weld, but the odds are against it. A welder doesn't have to be certified to make a good weld. Most welds even critical ones like roll bars, race chassis etc are visually inspected. Would hardly be practical to cut cross sections out of or even X ray every weld on a NASCAR or Indy car chassis.
This is but a small section of my good friend Mike Janis's US Nationals winning Pro Mod chassis under construction : https://www.facebook.com/photo.php?f...size=960%2C717
When the chassis was certified by NHRA the welds were visually inspected. And no, there isn't an ugly weld anywhere.
Old 01-16-2014, 02:43 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is offline
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
Even if the "bad welds" had good penetration, I wouldn't want them on my truck. They are truly UUUUUgggggyyyyyy!
Old 01-16-2014, 04:51 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is online now
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
I really suspect that we are looking at bad welds "on purpose" in that instagram example. I would think that anybody with half a brain would have figured out something wasn't quite right with those welds looong before they spent all that time doing popcorn welds.
10 Best Ford Truck Instagram Accounts Curated Content Editor General Automotive Discussion 0 12-08-2016 03:25 PM
Another 6.0 stolen jlillie 6.0L Power Stroke Diesel 3 04-21-2016 08:35 AM
Follow us on Instagram 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 0 01-06-2016 11:27 AM
Fleeterbomb - From Beater Fleet Truck to King of the Track - MPT's Project F150 5.0L MorePowerTuning Vendor Specials, Discounts, Product Announcements & Group Buys 0 12-19-2014 12:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
