weldporn: the beautiful and the ugly - Page 2 - Ford Truck Enthusiasts Forums
Old 01-16-2014, 04:31 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Not when you hire the fabrication done and that's the finished product you're presented with by the "welder". Anyone who says you can't tell a good weld from a bad one in a picture is a bad welder in denial.
Old 01-16-2014, 04:50 PM
AXracer's Avatar
I lost count years ago the number of bad solderings I fixed in my jewelry business (Precious metal "soldering" is actually brazing or welding) done by people who claimed to be professionals. When a new customer would ask why I charge more than the guy at the mall, my answer was "Probably because he knows how much HIS work is worth!". Then I'd say, "when his cheap repair breaks again it will then cost you two or more times my quote to undo his work and fix it right".
Old 01-16-2014, 05:20 PM
AXracer's Avatar
Mig welds do look different from TIG welds, but it is easy to distinguish a good MIG weld from a bad one. Anyone who can't tell from these pictures which is a good MIG weld and which is a bad one I suggest you go back and reread my MIG welding tutorial.
Every one of my students was able to be able to run a bead close to the second picture after a 4 hr class.
Old 01-16-2014, 07:15 PM
Marauder2004's Avatar
Marauder2004 Marauder2004 is offline
Marauder2004 has a good reputation on FTE.Marauder2004 has a good reputation on FTE.
As an NDT Level II (VT, MT, UT), I have to agree with AX. A good picture usually offers enough information to make a quick assessment, although a well-lit in-person view is always best.
Old 01-16-2014, 08:36 PM
Chris 56 f6's Avatar
Chris 56 f6 Chris 56 f6 is offline
Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.
I have welded enough to know I should take a class .
My question is how do you make welds like this and are they good welds?
Old 01-16-2014, 08:37 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
My wood joints are far superior to my welding. Of course I do woodwork for a living so I do it all the time. My welding is good when I am doing it a lot, but when I weld some small thing, like making a tool for my woodworking, it takes me a while to get the hang of it again. When I start, after many months of no welding, mine look pretty bad (but not as bad as the exhaust pipes that Ax posted). So I practice on some scrap until I get it going again. My horizontal slot mortiser that I made 10 years ago and my home made 5' x 9' utility trailer have never had a failed weld and they both get used constantly. I am hoping that when I actually start driving my truck I will find that all my welds were good.
Old 01-16-2014, 09:47 PM
AXracer's Avatar
Chris, if you are MIG welding, don't be disappointed if your welds don't have that "stack of dimes" look like these pictures. That is done with TIG, not MIG. TIG is more closely related to torch welding, the TIG torch does not touch the metal, it heats with a concentrated high voltage plasma arc and melts a puddle of metal to fuse the metal together, then a filler rod is poked into the molten puddle and quickly withdrawn to add more molten steel to the puddle. the torch is advanced to the edge of that now frozen puddle and the process is repeated, producing the stack of coins (NOTE: no electricity flows thru the filler rod in TIG, it is just a source of additional steel). With MIG electricity flows thru the filler wire when the wire is shorted out by touching it to the metal. The high current flowing thru the poorly conductive thin wire heats it very hot and the white hot molten filler wire jumps to the metal, heating it hot enough to melt the filler and the metal being welded together. as the filler wire is melted into the metal more wire is advanced keeping the short circuit going and the weld is continuous as you advance the stinger along. since the weld is continuous, no "coins" will form. (It is important to understand how the weld is produced in MIG to fully evaluate the quality and correct your welds. That's the problem with most how to MIG books and tutorials, they don't give you enough information on the difference in what is happening to be able to distinguish between a bead that was made with too low a power setting and one made by moving the stinger at too fast a rate. I will add a trouble shooting section to my tutorial in the next few days, so watch for it to pop back to the top.) You can get a rippled effect in a MIG weld by "weaving" the stinger, Weaving produces a wider bead without making it higher or creating too much heat and also allows the welder to concentrate the heat to the heavier piece when welding two different thicknesses together. Weving is done by moving the stinger in a series of cursive "e"s or "w"s pulling the edge of the puddle back on itself as you advance it. A good woven MIG weld will look like this:
Old 01-16-2014, 11:05 PM
Thanks ax. I will look for your post. I really should pull my tig welder out from under my welding table and start using it.
Old 09-17-2015, 09:08 PM
c91x's Avatar
c91x c91x is offline
c91x has a great reputation on FTE.c91x has a great reputation on FTE.c91x has a great reputation on FTE.c91x has a great reputation on FTE.c91x has a great reputation on FTE.
Quote:
Both of those welds are mig. First one is stitched (series of hot tack welds) and the second is just mig with a whip in his pattern. You can most certainly stack dimes with a mig.
Old 09-17-2015, 09:12 PM
c91x's Avatar
Didn't realize I brought this thread back from the dead. Oops
10 Best Ford Truck Instagram Accounts Curated Content Editor General Automotive Discussion 0 12-08-2016 02:25 PM
Another 6.0 stolen jlillie 6.0L Power Stroke Diesel 3 04-21-2016 07:35 AM
Impersonator on Instagram and FTE! SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 45 04-02-2016 08:20 PM
Follow us on Instagram 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 0 01-06-2016 10:27 AM
Ford Atlas Concept Truck hsfbfan 2009 - 2014 F150 52 02-17-2013 04:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
