How to change ATF in the '00 and '01 Ex with pictures - Ford Truck Enthusiasts Forums
Old 01-15-2014, 08:35 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
I went to Walmart and found 5 quarts of Mercon V and asked for more and after 20 minutes they emerged with 17 even though they said 5 was all they had. (about $4.50 each)
Raise the truck up and locate the rubber plug in the bellhousing, and pry it out (below)
Now look in the hole for the drain plug, you will have about 10" total of viewing area. Use a little mirror and flashlight if it helps. If you don't see it tap the starter until you do, I tapped it twice before I saw it. This picture was taken through the hole.
When you spot it turn the engine at the converter with a screwdriver until it is in the middle of the hole.
Use an 11 mm socket on the converter and a 13 mm on the pan.
The truck has 170k miles on it but I am assuming the previous owner changed it a while back since it looked and smelled pretty good. (Makes my hand look weird)
I had to improvise with the spout since Ford made the filler tube nearly horizontal.
I figured it would take 16 quarts but Wal-Mart came up with 17 so I took those and it only used 15 quarts. With the condition the oil was in it will be just fine.
Old 01-15-2014, 09:09 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
So in 2002 they don't have the TC drain plug?
I never looked on my 03, I flushed it.
Old 01-15-2014, 09:16 PM
See post # 12
http://www.ford-trucks.com/forums/81...ml#post7102658
Old 01-15-2014, 09:20 PM
hav24wheel's Avatar
Good call.
Good write up, I always drained the pan and TC on my older vehicles during a service. My 03 was first one I ever flushed
Old 01-15-2014, 10:00 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Well done, Brent! This will make yet another good addition to the tech folder, especially for those that have an earlier model Ex with the TC plug, and they don't wanna do the Mark K flush.
Quote:
Originally Posted by EXv10 View Post
I'll quote that post here so peeps don't have to flip to another thread if they don't want to.
Quote:
Originally Posted by Mark Kovalsky View Post
All bellhousings have a rubber plug in the bottom, whether or not there is a drain plug in the torque converter.
Ford stopped installing drain plugs in the torque converter in August, 2001, which is shortly after the 2002 model year started. All 2001s left the factory with a drain plug in the torque converter.
If anyone comes across this thread in a search, or if anyone has a 4R100 and you don't have the TC plug, and aren't familiar with Mark K's flush for the 4R100 trans, that how to can be found here:
Mark K's 4R100 Transmission Fluid Change (article)
Mark K's 4R100 Transmission Fluid Change (with pics)
Heh, I have a 2000 Ex and didn't even think about popping the TC plug. You just made things a heckuva lot easier for me Brent. Reps!
Stewart
Old 01-15-2014, 10:12 PM
sammie0126's Avatar
sammie0126 sammie0126 is offline
sammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputation
Great pictures Brent. I have read how to remove that plug and turn the converter but I never understood exactly what they meant, until I saw your pictures.
Old 01-15-2014, 10:21 PM
Quote:
Ha, that was a daily function many years ago when I was R&R'ing transmissions. I noticed the V-10 took a little more muscle and we never bothered to tap the starter back then. If we could see the flex plate teeth we would push on them with a screwdriver sometimes too.
Old 01-17-2014, 06:08 PM
Deserves a bump.
Old 01-17-2014, 08:36 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Cool thread Brent, I really like the useful pics. The flush procedure gets more of the fluid out, but it's a more complex operation than what you did there. Those without the converter drain plug would do well to flush rather than drain and fill because you can't get most of the fluid out.
Reps SENT!
Old 01-17-2014, 10:08 PM
Quote:
Reps SENT!
Thanks. It will be just fine.
Old 01-17-2014, 10:19 PM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
Is this the same no matter what motor you have? If you want to do the flush and do have the TC plug would it be foolish to not drain it before the flush?
Old 01-18-2014, 12:07 AM
Quote:
It's either the flush or the drain and even though the flush might remove a little more it's not enough to make a difference.
Old 01-18-2014, 02:59 AM
icentropy icentropy is offline
icentropy has a good reputation on FTE.icentropy has a good reputation on FTE.
Nice write up! Looks like this will be my next item of maintenance. I think my tranny may be starting to slip accelerating uphill but hard to tell on these icy bumpy roads. Got me thinking about the tranny fluid I've never changed...
Old 01-18-2014, 07:59 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
If you are doing a flush there is no reason to drain the torque converter first.
The procedure is the same no matter what engine you have.
1950 F-1 5.3/60e swap complete lilpanther 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-22-2017 10:02 AM
Advice on buying rodded 56 seeked NitroFreak 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 09-10-2015 03:12 PM
How to change the thermostat and burp the Ex V-10 with pictures EXv10 Excursion - King of SUVs 32 09-01-2014 12:41 AM
How to replace the '00 Ex driver door actuator the easy way, with pictures EXv10 Excursion - King of SUVs 18 11-26-2013 07:08 PM
Free your hatch key lock, with pictures (not the actuator) EXv10 Excursion - King of SUVs 20 11-16-2013 03:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
