I thought I would share some recent maintenance on my 2003 X.
MODS Edit:
The coding you used to try and post pictures of your Excursion caused a problem with the forum. The pictures didn't show, and it actually caused your thread to detour to a "Page Requested Not Found" page. I had to use some fancy-shmancy Internet Kung Foo to access this post and remove the offending bad code.
Please try again with proper coding. Do not use iframe coding.
Master Stewart: Do you hear the grasshopper coding at your feet?
Young FTEr: [looking down and seeing the insect] Old man, how is it that you hear iframe things?
Master Stewart: Young man, how is it that you do not?
Ha. Body lift.. I thought it was the typical body lift for tire clearance. That sure does make it easy to do lots of cleaning too.
I was gonna say, why would someone do a body lift on a vehicle so easy to suspension lift. Cool, I'd be all over that with simple green and a costco sized package of paper towels.
I can't see the pic . Can some one copy and re post them or something. I really want to check this out. Been wanting to do a body lift on mine to make it easier to clean too
Master Stewart: Do you hear the grasshopper coding that is at your feet?
