Pulling the cab for engine work
Old 01-17-2014, 09:08 PM
nodesy's Avatar
nodesy
nodesy is offline
So I am hearing that the easiest way to pull and work on the engine is to pull the cab. Are there any how-to's out there or do I have to just wing it? Thanks!
Old 01-18-2014, 07:28 AM
Magnus E's Avatar
Magnus E
Magnus E is offline
I don't know the answer but figured I'd ad a couple of cents. My ford dealer just did the ARP head studs for me. When I asked if they were lifting the cab off to work on the engine they said no. In their shop they only lift the cab on the pickup trucks not on the Excursion. Instead, they removed pretty much everything that is in the way (including heater core etc.) to get access to work on the heads. With this, I can only assume (but don't know) that lifting the Excursion cab is more work than leaving it on.
Old 01-18-2014, 11:28 AM
Archion's Avatar
Archion
Archion is offline
There is no cab like on a truck, it's the whole body. Much more involved, but has been done. You could possibly pull most of the front clip off, but that's about it without yanking the whole thing.
ClassicKidNick
06-07-2021 11:31 PM
NauticaEE
06-09-2010 10:22 AM
rblaine9000
08-14-2009 01:11 PM
phil85207
6.4L Power Stroke Diesel
05-19-2008 12:26 AM
wantaford
1999 to 2016 Super Duty
15
08-24-2007 09:22 PM
Quick Reply: Pulling the cab for engine work
