moter information - Ford Truck Enthusiasts Forums
moter information
Old 01-15-2014, 07:23 PM
bernette's Avatar
bernette bernette is online now
bernette has a great reputation on FTE.bernette has a great reputation on FTE.bernette has a great reputation on FTE.bernette has a great reputation on FTE.bernette has a great reputation on FTE.
moter information
hi! i would like information on flat heads. i made a mistake and started a thread in the Y block motor forum. its to better understand what the letters and numbers mean. i know what the cubic inches mean,like 239. why are there 59b models . i don,t know all the different models by heart,but i hope you get the ideal. i will post a picture of my motor.
Old 01-15-2014, 07:59 PM
bernette's Avatar
here a short video of the second start up. i will get better pictures.
Old 10-14-2014, 05:40 PM
41505379's Avatar
41505379 41505379 is offline
41505379 is starting off with a positive reputation.
Identifying flathead
An easy way to identify the later model flathead V-8 which you don't have, is by the water outlets at the front of the head and the distributor on the right side at an angle with the distributor cap where it can be serviced easily. Also the oil add tube comes out of the intake manifold near the front and towards the drivers side at an angle. They were used in 1948 to 1953 Ford trucks and in the 1949 to 1953 Ford cars in the USA. They had 239 cu inches and had 24 bolts per head.
The next older ones had 24 studs per head with nuts holding the heads on. My facts are fuzzy here. I think these are the 59b models installed in 46 and 47 and in the cars from 1946 to 1948. These have distributors that run directly off the front end of the camshaft and look sort of flat compared to the 1941 and previous v8s. I think this is what you have.
The 1941s I think had 221 cu inches with fewer head studs and a distributor that resembles an old round diving helmet that also runs off the front of the camshaft. I'll stop here as the farther back I go the less I know. The first few years of the V8s had water pumps up at the heads. Ford found out that they belong at the bottom and changed that. You don't have one of those engines. Hope that helps some. Patrick
Old 10-16-2014, 08:21 PM
bernette's Avatar
thanks alot!
Old 10-23-2015, 06:27 PM
artscott61's Avatar
artscott61 artscott61 is online now
artscott61 is gaining momentum as a positive member of FTE.
Hey what a good flathead book to purchase?
Old 10-23-2015, 07:15 PM
41505379's Avatar
Flathead book
Art, I'm not sure about a good flathead book. All I've really got is the truck manual which covers 48 to 51 with a 1952 supplement I think. Also some experience with a 41 Ford coupe starting in 1958 and later with a 53 Ford.
Your best bet is to start a new thread, then you will get a lot of feedback.
Patrick
Old 11-14-2015, 03:07 PM
artscott61's Avatar
Just found a number to call which I will come Monday. 800-513-8133 Hot Rod Library. Complete flathead Ford engine manual. We will see. I just bought a box full of complete 94's and some rebuild kits have not had time to go through all of them but the carbs are complete.
Old 11-19-2015, 04:38 PM
artscott61's Avatar
Well so much for the phone # on the flathead motor. Not anything about motors. I think that this was a ted smith book. If that is the right name it looks like he is trying to sell the business I don't how old my info is.
Model year differences? MisterMichigan Excursion - King of SUVs 19 01-04-2017 06:00 PM
Parking meters Rusty_S General Automotive Discussion 0 12-12-2016 10:24 PM
'73 F100 Questions championofthesun 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-12-2015 12:17 PM
F5 VIN question old58 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 09-23-2014 06:12 AM
A question that i cant get answered. jayboe 1966 - 1977 Early Broncos 5 08-24-2006 01:46 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
