1990 460 propane issue - Ford Truck Enthusiasts Forums
Old 01-15-2014, 07:00 PM
460jared96's Avatar
460jared96 460jared96 is offline
460jared96 is starting off with a positive reputation.
Hey guys, my truck recently decided it didn't want to start on propane... It's a 1990 f250 460 with dual gas tanks as well as dual propane tanks. Last time I ran it on propane was about two weeks ago, It kicked back a couple times and was sputtering, and wanted to die. I turned it off, it fired right up, but then started to die again. I would give it gas (propane) which would keep it alive for a bit, but then it would die. Then check engine light came on and kept dying. I switched it back to gas, ran fine, didnt studder, check engine light turned off. Ive been running it on gas the last two weeks and its had ZERO problems. But now it wont start on propane. Ive heard that the propane freezing is a problem, as well as something to do with the regulator. I let it warm up at idle for 15 minutes and it was about 5 degrees celsius out.
thanks in advance
Jared
Old 01-15-2014, 08:23 PM
joey2fords's Avatar
joey2fords joey2fords is offline
joey2fords is gaining momentum as a positive member of FTE.
with a properly functioning cooling system, and an ambient temperature of 5 celsius, its unlikely your propane regulator has frozen up.
1 possiblity is that your (gasoline) fuel shut-off solenoid is malfunctioning, flooding your engine with 2 fuels, instead of 1.
Old 01-16-2014, 01:25 AM
460jared96's Avatar
Ok I will look into that. And you're saying that's why it's not starting now right? Not why it was sputtering and kicking back.
Jared
Old 01-16-2014, 08:18 AM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
Quote:
Jared
No, he's saying it's a possibility. You need to determine if what he's saying is actually what's happening. To me, the simplest way would be to pull the relay or fuse for the in-tank fuel pumps (thereby eliminating the chance that any gasoline is being fed into the cylinders) and then try to start it with just the propane. If it starts and runs fine, then that's confirmation that there's a problem with flooding.
If it doesn't, then there's probably an issue with the propane system. But, not knowing anything about propane systems, I can't give you direction on it.
Old 01-16-2014, 10:38 AM
gasman6674's Avatar
gasman6674 gasman6674 is online now
gasman6674 is gaining momentum as a positive member of FTE.
Please post info/model #s on the equipment on your truck, pictures would be nice also.
First guess is the vaporiser is leaking thru and will nee to be rebuilt. If you have a hose the goes from the vaporiser to the mixer/carb pull it off then turn the key to on or supply vacumn if you have a vac fuelock. If get fuel its a bad regulator
regards
Old 01-16-2014, 01:04 PM
460jared96's Avatar
Ok I'll look into the model # I just bout the truck and have no idea how propane works at all. It was converted back in 1992... I have a friend moving back to Vancouver this week and he is much more mechanically savvy than me. I appreciate the feedback from you guys
Jared
Propane Conversion on my Edge - 6 month report PaulsEdge Alternative Fuels, Hybrids & Mileage 7 01-09-2017 08:09 AM
1976 Ford F100 4x4 project hansol04 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-03-2016 11:40 AM
1990 460 weird idle and back firing 460jared96 1987 - 1996 F150 & Larger F-Series Trucks 4 10-11-2014 10:26 PM
Flowmaster 10 series 460jared96 1987 - 1996 F150 & Larger F-Series Trucks 10 12-16-2013 04:48 PM
Will not run on gas, runs fine on Propane Cor Fuel Injection, Carburetion & Fuel System 9 08-11-2004 04:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
