Hood Latch Rivets - Ford Truck Enthusiasts Forums
Hood Latch Rivets
Old 01-15-2014, 06:15 PM
cts1954 cts1954 is offline
cts1954 is starting off with a positive reputation.
Hood Latch Rivets
Does anyone know where I can get a couple of shoulder rivets for the hood latch on my 52 F1. They are a 5/16 shoulder rivet that are used on the pivot of the latch and the lever.
Thanks
Old 01-16-2014, 01:17 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
I don't recall anyone ever asking that here before. Maybe ND Bill
would know if there are any. I am thinking ya may have to have
them made for you. I think Ross or others will chime in.
Old 01-16-2014, 09:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Hmmmm.... You could probably make one from a bolt, this is all I could find. A bag of 50 may not cost a bunch, or you may be able to get a "sample"....
http://www.spaenaur.com/pdf/sectionE/E7.pdf
Old 01-16-2014, 11:06 PM
Yes Ross I would prolly try modifying a soft bolt with a bench grinder or if lucky a lathe. Than heat it red hot and rivet it down. I bet it would take me a few tries to get
it tight but not to tight. Sounds like a fun project to do. Several ways to do it.
Old 01-17-2014, 10:45 AM
Thanks, they are available but getting the small amount required is hard. Normally McMaster Carr has everything but I don't see these. I will make something out of a 5/16 shoulder bolt. The only reason I am replacing them is at one time my latch was chromed and I need to drill out the old rivets so I could strip the old chrome off.
2011 SD driver door latch denism28 1999 to 2016 Super Duty 4 11-20-2014 02:50 PM
Supercab Lower Door Latch Fixed !!! fbh31118 1999 to 2016 Super Duty 13 10-09-2014 11:26 AM
Hood won't latch 2000 xlt woodworx Expedition & Navigator 5 12-02-2007 06:15 PM
vent glass rivet spartamouse1 1966 - 1977 Early Broncos 5 02-18-2003 08:57 AM
1946 hood latch panel truckzilla 1947 and Older Ford Trucks 4 06-03-2002 11:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
