Shorty Header choices...302 in a 56 F 100 - Ford Truck Enthusiasts Forums
Old 01-15-2014, 06:03 PM
ulev1st ulev1st is offline
ulev1st has a good reputation on FTE.ulev1st has a good reputation on FTE.
Stainless,ceramic coated,chrome or painted..
Then of course there are a BUNCH of manufactures...Who has what and are you happy with them?
Old 01-15-2014, 07:17 PM
3golfjack's Avatar
3golfjack 3golfjack is offline
3golfjack is gaining momentum as a positive member of FTE.3golfjack is gaining momentum as a positive member of FTE.
Hi Don.
I went with the ceramic coated BBK 79-93 mustang shorty headers connected to a 2.5" H pipe exhaust. Stainless will start getting blue as you use them from the heat.
[/IMG]
Old 01-15-2014, 07:29 PM
Thanks Jack....what have you done to your baby lately?
I've been unable to work on mine since late October because of rotator cuff surgery...still in Physical Therapy three days a week..but when they release me I'm gonna get back on it!
Old 01-15-2014, 07:42 PM
3golfjack's Avatar
I hate to say it but the past month or two I've been lazy. I've have gotten out a number of times driving. I was in Germantown last weekend. I've got all the stuff to put the heater in if I simply make the time to do it.
Old 01-15-2014, 07:48 PM
Wayne Waldrep's Avatar
Wayne Waldrep Wayne Waldrep is offline
Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.
I've used the Ford Racing shorties and the BBK shorties, both in ceramic. The BBK headers held up much better for me.
Old 01-15-2014, 07:56 PM
carnut122's Avatar
carnut122 carnut122 is offline
carnut122 is gaining momentum as a positive member of FTE.carnut122 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 3golfjack View Post
Hi Don.
[/IMG]
I have the same application/year BBK chrome shorties and they're also discolored from the heat. Other than that, I'm happy with them. I'd probably get the ceramic coated if I had to do it all over.
Old 01-16-2014, 06:40 PM
I decided to pull the trigger on the BBK ceramics..thanhks for your input guys!
Old 01-16-2014, 07:44 PM
jthesby jthesby is offline
jthesby is starting off with a positive reputation.
What kind of room do those bbk's leave for mII starting shaft? Been eyeing Sandersons for the clearance.
Old 01-16-2014, 10:06 PM
Not sure...maybe Jack can help you out on that.
Old 01-17-2014, 05:55 AM
carnut122's Avatar
Quote:
Mine had plenty of room for the starter. If I had it to do all over again, I'd consider the gear reduction starter to save about 5-10 pounds.
Old 01-17-2014, 06:15 AM
Quote:
Darn auto correct, meant mII steering shaft.
Old 01-17-2014, 07:50 PM
carnut122's Avatar
I'm a dyslexic typist, so I feel your pain. I have plenty of room, but I'm running a complete TCI frame and MII suspension. I also have a 33" steering column. I angled the mounting bushings for the rack and pinion to give the input a more direct angle to the steering wheel. It all seems to work well.
Old 01-17-2014, 08:01 PM
drptop70ss's Avatar
drptop70ss drptop70ss is online now
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
Since I dont tune for max HP I use whatever fits and then finish by budget..
off topic but this is a very nice truck, hate to see it burn to the ground because of a cheap $1.99 plastic fuel filter. I would toss that thing immediately and get a glass or metal one. I have seen those crack from engine heat and age and it isnt pretty!
Old 01-17-2014, 10:07 PM
Branded Branded is offline
Branded is gaining momentum as a positive member of FTE.Branded is gaining momentum as a positive member of FTE.
I've seen the glass type break also and cause fires.
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
