Fuel Sender for Stewart Warner Gauge
Old 01-16-2014, 11:46 PM
dmack91's Avatar
dmack91
dmack91 is offline
Anyone using a Stewart Warner gauge in their truck with a stock tank? I know I need the SW range sending unit, but don't know which direction swing or depth?
Long shot but thought I would try.
Thanks,
Dave
Old 01-17-2014, 09:22 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Thanks,
Dave
I can't say for sure but the SW gauge is probably looking for a resistance reading of 240-33 ohms. This is common for some aftermarket, marine, and even some OEM sending units. You can get an adapter from Sacramento Ford Parts that will allow a matching 12V aftermarket fuel sender to fit your stock tank but it is not likely you can make the gauge work with the stock sender.
Old 01-17-2014, 11:58 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
I also have a S-W fuel gauge I got at a swap meet (for $1!), this is what I found for senders from their catalog. Note it is for 5-hole mounting, I'd swear the stock sender has 6 holes.
Old 01-17-2014, 12:29 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
Yea Ross the stock is a 6 hole and you need an adapter, I made mine on my lathe. They can be found for 20-30 dollars. The ohm range needed will depend on the gauge, SW along with the others make several ranges for use with stock senders so you will need to know the range for your gauge.
Old 01-17-2014, 09:46 PM
dmack91's Avatar
dmack91
dmack91 is offline
Thanks all. I knew about the ohm range, but was wondering if anyone knew for sure which one would fit our stock tank. Looks like I will go with the top one on the list.
eric8
02-17-2019 03:33 PM
Gigemags05
02-03-2016 03:10 PM
John & Old Ford
02-01-2013 07:36 AM
highoctane74
04-01-2012 09:09 PM
69f250mg
08-13-2001 02:58 AM
Quick Reply: Fuel Sender for Stewart Warner Gauge
