Searching For Parts - Ford Truck Enthusiasts Forums
Searching For Parts
Old 01-15-2014, 04:42 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Question Searching For Parts
Gentleman I am in need of a set of rear lower shock mounts . Our truck does not appear to have had any installed from the factory . It's a Mercury version of the F3 . The mounts I have seen are built into the spring U bolt clamps. Does anyone have a spare set available for sale .
Old 01-15-2014, 05:13 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Normally F-3s don't have rear shocks. The F-2 lower mounts, that were standard, were optional on F-3s. Am I right that the F-2 model wasn't sold in Canada? I've parted out a couple F-2s, but sorry that the lower mounts already found new homes. Stu
Old 01-15-2014, 05:51 PM
oscajo oscajo is offline
oscajo is starting off with a positive reputation.
parts
Quote:
I have the mounts off of a 52 F1. They look great and if you would like I will send them to you and when you get them just send me back 30.00 to cover the parts and shipping cost. if that sounds good send me an address and I will get them off to you. Here are some pictures of them.
Old 01-15-2014, 05:53 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
The rear shock mounts are different between F1 and F2/3 trucks. The F1 are smaller than F2/F3 and will not work on thicker rear axle of the F2/F3.
I parted out two 52 F3s recently and both had the rear shock mounts, uppers and lowers. The first set went to aussiecowboy for his F3 and I'm saving the other set to hopefully use in my 51 when I install the 9" rear.
With so many F2/3s popping up recently, and most being modified, I'm sure that you'll find a set.
Old 01-15-2014, 06:49 PM
oldmerc's Avatar
oldmerc
I'm a patient man and you're right something will pop up sooner or later . I do however thank you for your responses .
Old 01-15-2014, 10:36 PM
Jolly Roger's Avatar
Jolly Roger Jolly Roger is offline
Jolly Roger is starting off with a positive reputation.
I've been looking for these as well. If I stumble upon a stash of them I'll let you know. Here's to hoping!!!!!!
Old 01-15-2014, 10:39 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
HEY! Welcome back Jolly Roger! Long time no see!
Old 01-15-2014, 11:27 PM
jmadsen's Avatar
jmadsen jmadsen is online now
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
Roger <> Roger
Sorry couldn't resist!
I have a 9" rear end laying in the garage waiting to go under the F-1 and a pair of those 3" mounts here somewhere? There may have been a second pair but will have to dig around a bit to see. people have started to call me a packrat lately so I guess I better start selling something
I'll see if I can scare up an extra set of those brackets.
Old 01-16-2014, 05:37 AM
Josh - Jeff B is gonna call you about your 8-22.5s. You might at the same time ask if he has a set of these he'd part with. Stu
Radiator Housing mount bolting position? oscajo 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 06-29-2014 10:11 PM
New body mounts Trapped_in_GNV 1999 to 2016 Super Duty 0 05-25-2014 09:49 AM
Solid Mount 460 engine mounts JB78f150 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-21-2014 04:56 PM
460 motor mounts? oldmansimek 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 12-25-2006 12:50 PM
40 Pickup Cab Mounts alittle40 1947 and Older Ford Trucks 3 12-26-2001 09:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
