pcv valve? - Ford Truck Enthusiasts Forums
pcv valve?
Old 01-15-2014, 03:13 PM
Braden10 Braden10 is offline
Braden10 is starting off with a positive reputation.
pcv valve?
I have an 01 f150 with mutliple codes. the truck was running bad a few months back and when i checked it out the pcv valve had somehow popped out. i put it back in and kept driving. spark plugs needed changing and i ripped a wire.bought new set and only changed half of the wires for labors sake. could half old, half new wires cause it? (I doubt but just checking) I have since checked the pcv valve again and it's still in but it doesn't seem seated all the way or as snug as it should be. could that be the problem? any ideas would be much appreciated. P0401 powertrain-exhaust gas recirculation flow insufficient
P0171-powertrain-system too lean (bank 1)
P0302-powertrain cylinder 2 misfire
P0305-cylinder 5 misfire
P0442- evap
Emission leak (small leak)
Old 01-15-2014, 04:20 PM
david campbell david campbell is offline
david campbell is starting off with a positive reputation.
This is more than likly your EGR Value they tend to stick. you can try cleaning it. some times that works. but that is just short time fix.
P0171-powertrain-system too lean (bank 1) one of 5 things
1. Fuel System:A malfunctioning fuel system can reduce the amount of fuel coming into the engine, causing a run lean condition. A clogged fuel filter can reduce both fuel delivery and fuel pressure. Low fuel pressure will reduce the fuel flow at the fuel injectors.
2. Oxygen Sensor:O2 Sensors are used to monitor the amount of oxygen in the engine's exhaust. The on-board computer uses the information from the O2 sensor to make the air/ fuel mixutre richer or leaner. If the oxygen sensor malfunctions, it can send the computer incorrect information about the current state of the exhaust.
3. Air Mass Flow Sensor: The air mass flow sensor monitors and tells the on-board computer how much air is entering the engine. As the air flow into the engine increases, the sensor sends a signal to the on-board computer to increase the amount of fuel being delivered to the engine. If the sensor does not send an accurate signal, the air flow could increase without a corresponding increase in fuel.
4. Air Leaks:Engines have a sea of hoses of various shapes & sizes. These hoses do not last forever. Constant exposure to high heat will eventually cause a hose to deteriorate. If this hose is not replaced, it will cause an air leak. When an air leak occurs, excess air finds its way into the engine.
5. Computer Malfunction:On-board computers monitor every aspect of the engine's operation - but that doesn't mean that the computer cannot develop problems. Any electronic device can malfunction. The computer could fail to send appropriate fuel delivery signals to the fuel injectors, which would cause the engine to run lean.
P0302-powertrain cylinder 2 misfire, P0305-cylinder 5 misfire
This is A Tricky one. it could be something fuel related, ignition related or air related.
P0442- evap
with that many codes you better take it in and have them hook it up to a scan tool.
Old 01-15-2014, 04:29 PM
Thanks! That gives me a place to start. Any idea if the somewhat loose pcv valve could be causing it?
Old 01-15-2014, 08:22 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
If the PCV valve is loose, fix it. It can cause a variety of issues.
Don't mess with the EGR valve, they rarely fail. Check the DPFE sensor for proper operation and check for a clogged EGR port.
Fix the misfires and see if that also solves the "lean" code.
Reset the PCM after repairs so that it starts fresh.
2003 Ex V10 Extremely Rough Idle BigBair Modular V10 (6.8l) 44 10-25-2016 10:08 PM
2002 E250 5.4 starts out running fine, crawling in 10 minutes Ryan Simpson 1968-2013 Full Size Vans 15 04-12-2016 07:53 AM
02 E250 5.4L p0171, p0174 and multiple misfires Ryan Simpson Modular V8 (4.6L, 5.4L) 9 04-11-2016 11:32 AM
96 4.0 codes P0174,P0305,P0306 Pipe Burn Ranger & B-Series 15 06-29-2010 01:27 AM
PCV and P1405 code? DeanG 1997 - 2003 F150 2 03-24-2006 03:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
